It is currently Thu Jan 17, 2019 3:02 am
Post new topic Reply to topic  [ 21 posts ]  Go to page 1, 2  Next
PostPosted: Wed Jul 26, 2017 10:36 pm
Has thanked: 39 times
Been thanked: 1405 times
Occasionally the engine management light comes on and no code, so I thought one of those code readers may be of use, just wondering which one to get.
I have seen some that use bluetooth to "talk" to your mobile phone, so you must download an app as well.
So my question is, have you got a fault code reader, if so which one, and what do you think of it?
PostPosted: Thu Jul 27, 2017 10:40 am
Has thanked: 349 times
Been thanked: 1809 times
They're all much of a muchness these days - pretty much down to the software that references the code to the fault.
You'll probably end up going online to get the deep details anyway.....
Mine's a bluetooth, straight to the phone running a freeware app but the paid-for app opens much more in the way of capability (or so I'm told).
PostPosted: Thu Jul 27, 2017 1:26 pm
Has thanked: 1185 times
Been thanked: 1079 times
I've got one of the stand alone type. Just plug it in and read off the screen. Has worked OK when I have used it. Reads the codes and clears them if you want to. It was about fifteen quid IIRC.
Some of the software based solutions are a lot more sophisticated.
PostPosted: Thu Jul 27, 2017 1:31 pm
Has thanked: 60 times
Been thanked: 623 times
All depends on the Year, make and model, a fault like this needs more in depth investigation, Having a code reader and getting a code is nothing, Its knowing what to do with the information and diagnosing it correctly that's what takes the skill rather than aiming the parts cannon at it and pulling the trigger
basic handheld readers don't usually read historic codes
PostPosted: Thu Jul 27, 2017 1:54 pm
Has thanked: 212 times
Been thanked: 281 times
I've got a "Panlong Bluetooth OBD2 Reader for Android" which I got for about 12 quid on Amazon. I use it with Torque Pro on my phone (which cost a couple of quid or so, I think). Works like a charm. Don't leave it plugged into the car overnight though -- lent mine to my brother and he did that and flattened the battery. They clearly use a fair amount of juice! :lol:
PostPosted: Thu Jul 27, 2017 4:36 pm
Has thanked: 999 times
Been thanked: 1878 times
Correct,it's ok the reader telling you there is an engine misfire in cylinder 3 or whatever but it could be a multitude of things causing it to misfire.
PostPosted: Thu Jul 27, 2017 4:52 pm
They do have their uses though. I bought mine because I was having trouble with the engine light on my van (Transit Connect). Now I'm pretty rubbish with cars & vans, I don't usually mess with them beyond minor serviceable bits, but the bluetooth dongley thing said it was a sticking EGR valve.
A quick bit of googling told me it's a common issue in vehicles that do a lot of short local journeys, and one possible solution was an Italian Service (basically, take it on a motorway and rag the nuts off it for half an hour). So I put a tank of that pricey Shell V-Power diesel in it, as it's supposed to contain various clag-removing chemicals and detergents, and really spanked it for a bit. I was as surprised as anyone when it actually worked! Engine light was off the next time I started it up, and the fault code was cleared and it's been fine ever since (running on normal grade diesel). That was at least 18 months ago and it's had two services and MOTs since then.
Maybe I have just been incredibly lucky, but I consider it 15 quid well spent.
PostPosted: Thu Jul 27, 2017 5:33 pm
Has thanked: 1509 times
Been thanked: 3834 times
Did it show a fault code for flat battery :wink:
For this message the author wine~o has received thanks - 2: chrrris, Dave54
PostPosted: Thu Jul 27, 2017 5:43 pm
A fault code is to be used as a tool to diagnose faults, A mechanical problem say a blocked pcv can give you map and maf faults
A cam/crank correlation code could be a worn timing chain, newer cars are getting even more complex with the likes of windows and wipers what are controlled by the bcm, ecu and ipdm/tipm/power distribution
PostPosted: Thu Jul 27, 2017 9:00 pm
Blank off the egr mate,it's a piece of p*ss to do and the van will run loads better!
I've done it with every tranny and connect I've had.
For this message the author steviejoiner74 has received gratitude : chrrris
PostPosted: Thu Jul 27, 2017 9:04 pm
You really should charge for jokes like that. . . :lol:
For this message the author Dave54 has received thanks - 2: multiman, wine~o
PostPosted: Thu Jul 27, 2017 9:19 pm
Thanks everyone. :thumbleft: :thumbright:
I want to get one so I know when it goes to be fixed am I being "strung a long" I understand that it may say its the fezwongle that's at fault and it needs a new zipzap to cure it, but I just want some where to start.
PostPosted: Thu Jul 27, 2017 9:38 pm
Has thanked: 696 times
Been thanked: 28 times
In that case a basic elm327 Bluetooth, wifi or usb will be sufficient, I have autodata, honda hds, delphi and wow diagnostic, I have the honda hds unit, also snooper unit and elm327 Bluetooth as well a generic obd scanner will only read basic diagnostic codes for in depth you will need equipment like I have. Hope that helps
PostPosted: Thu Jul 27, 2017 10:14 pm
Hmmm... Somebody else suggested I do that a while back too. I might actually look into that then, although it'll have to be pretty simple as I seem to have a special gift for making a mess of can/van/motorbike maintenance!
For this message the author chrrris has received gratitude : multiman
PostPosted: Thu Jul 27, 2017 10:34 pm
Has thanked: 104 times
Been thanked: 354 times
I bought one when I owned a Renault :lol:
Cheapy thing from ebay, runs on an Android app called 'Torque' Read/clear codes, check turbo boost pressures, tempertures, revs, air flows.... god fun to mess about with.
cron
