Ultimate Handyman Home
Cap stone
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Building Forum
panlid
PostPosted: Thu Jun 21, 2007 7:25 am    Post subject: Cap stone Add User to Ignore List Reply with quote
need to make a cap stone to replace a damaged one. they are painted so i am not worried about colour etc.
i have never done this before so would appreciate any advice.
i was going to make a mould with ply and fill it with concrete. do i need to line the ply with anything to help getting it out. do i need to add anything to the conc?
any ideas welcome.
thanks.
Back to top
tim'll fix it
PostPosted: Thu Jun 21, 2007 7:42 am    Post subject: Add User to Ignore List Reply with quote
I made some for some pillars in my garden, as I couldnt find anything the right size once I had rushed ahead and built the pillars Embarassed
I used some hardboard at the time and screwed 2x2 round the edges with planned sides to get a chamfer on the edges. Screwed them together and then poured a sharp sand and cement mix in and tamped flat. It worked a treat.
I wanted a coloured mix so added cememtone to the mix.
I would screw the mould together so you can, unscrew it once its set, rather than prising it apart
Decking
Back to top
panlid
PostPosted: Thu Jun 21, 2007 7:49 am    Post subject: Add User to Ignore List Reply with quote
hi tim.
good idea to screw. i was going to add something like 8mm stone. sounds like it could be a bad idea though in terms of getting a smooth finish.
did yours end up smooth?
Back to top
sparkydude
Approved Electrician
PostPosted: Thu Jun 21, 2007 2:30 pm    Post subject: Add User to Ignore List Reply with quote
The best idea, is to use a mould as said before, then put i mix of sharp sand and cement in for the first layer, the one you will see when the mould is released, then add your mix with the stones in to the rest of the mould, I would also add some chicken wire to mixture to add some reinforcement. You can coat the inside of the mould with vegetable oil to act as a realease agent.
Nick
Back to top
tim'll fix it
PostPosted: Thu Jun 21, 2007 2:51 pm    Post subject: Add User to Ignore List Reply with quote
not perfectly smooth but no holes in the faces,
then I didnt want perfectly smooth
I am amazed how well they have lasted been in 6 years this summer and no cracking or anything
 Description:
 Filesize:  42.85 KB
 Viewed:  762 Time(s)
 Description:
 Filesize:  44.29 KB
 Viewed:  762 Time(s)
Decking
Back to top
handyman
PostPosted: Thu Jun 21, 2007 3:20 pm    Post subject: Add User to Ignore List Reply with quote
tim, have you never heard of a jet washer Wink
Go on, adopt a greyhound http://www.dgrescue.org.uk/ ..........................................................................
Back to top
skiking
PostPosted: Thu Jun 21, 2007 3:42 pm    Post subject: Add User to Ignore List Reply with quote
Its the rustic look Laughing
Back to top
panlid
PostPosted: Thu Jun 21, 2007 4:55 pm    Post subject: Add User to Ignore List Reply with quote
will try the vegatable oil and sharp sand mix.
would you recomend a 3-1 mix?
tim they look good and i like the moss. dont you dare clean em!
Back to top
jason123
PostPosted: Thu Jun 21, 2007 8:27 pm    Post subject: Add User to Ignore List Reply with quote
Its cement and sharp sand in the ratio, not vegetable oil Rolling Eyes
We had to build a step some time ago, I knew the importance of a vibrating poker, made one with a bit of 15mm copper pipe and stop end, inside Id welded a nut onto a bit of round bar, worked a treat. If the mortar mix is vibrated you can add aggregates no problem.
Stella Stella Stella oy oy oy
Back to top
tim'll fix it
PostPosted: Fri Jun 22, 2007 9:08 am    Post subject: Add User to Ignore List Reply with quote
yes I like then moss too :grin:
I dont live in surburbia so I dont feel the need to jet wash everything within an inch of its life
I wouldnt go for such a strong mix (more cement is not better I was always told) 4 : 1 sharp sand to cement and I would put some frost proofer or plasticiser in the mix
jasons vibrating idea is a good one
I spent a lot of time stir the mix in the molds and bashing them with a hammer, but then my molds werent very deep. You could use an sds on hammer only as a vibrating poker
Decking
Back to top
panlid
PostPosted: Fri Jun 22, 2007 12:30 pm    Post subject: Add User to Ignore List Reply with quote
good tips.
will get my drumsticks out and give em a bash :grin:
anyway i live in surburbia and dont even own a jetwash Bang Head
Back to top
handyman
PostPosted: Fri Jun 22, 2007 1:58 pm    Post subject: Add User to Ignore List Reply with quote
jesus..........we have strong jetwash opinions now Rolling Eyes
Wink
Back to top
panlid
PostPosted: Fri Jun 22, 2007 5:02 pm    Post subject: Add User to Ignore List Reply with quote
i dont and never will own one!!!!!!!!1
i use my father in laws Laughing
Back to top
marksson
PostPosted: Sat Jun 23, 2007 10:17 pm    Post subject: Add User to Ignore List Reply with quote
Quote:
The mix should be a stiff as possible
Use the largest aggregate practicable
Use the optimum ratio of fines to coarse aggregate.
A low water to cement ratio is the number one issue that affects concrete quality. Do not add too much water.
My 8ish year old jet wash has seen the light of day maybe twice.
Building Materials Sourcing
Softly, softly catchee monkey
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Building Forum All times are GMT
Page 1 of 1
