It is currently Wed May 23, 2012 2:48 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 11 posts ]
 Post subject: Cannot take off tap
PostPosted: Wed Jul 01, 2009 11:51 pm
Looking for some advice please. I am trying to replace the washer for our kitchen mixer tap. I struggled with getting the tap off.
I have attaached a pciture of the tap.
Any advice would be appreciated.
File comment: Kitchen tap.
 Post subject:
PostPosted: Wed Jul 01, 2009 11:58 pm
OAP
Has thanked: 187 times
Been thanked: 2110 times
Assume you mean the spout.
Turn it so it's facing the window, and if you pull upwards as you go it should pop out.
 Post subject:
PostPosted: Thu Jul 02, 2009 1:13 pm
Thanks thescruff.
I meant the tap handle. I took off the spout last nite to have a good clean but it is still dripping.
I have managed to take off the screw but was not able to put it off the main body to replace the washer. Is there a special device i should be using to take it off.
Many thanks.
 Post subject:
PostPosted: Thu Jul 02, 2009 1:24 pm
OAP
The handle should just pull off once the screw is out.
 Post subject:
PostPosted: Thu Jul 02, 2009 7:51 pm
I thought so too but it won't move at all.
Thanks, I will try again this weekend.
 Post subject:
PostPosted: Thu Jul 02, 2009 8:00 pm
Has thanked: 125 times
Been thanked: 392 times
Sometimes they get stuck to the spline.
You can try and spray it with WD40, give it a few squirts over the next few hours.
I have had tap heads that have taken a hell of a lot of force to remove in the past!
DIY | Donnas dream house
 Post subject:
Another thing is that the tap looks like a quarter turn tap and so it might use a cartridge instead of a washer.
 Post subject:
PostPosted: Fri Jul 03, 2009 10:15 pm
Many thanks again for your reply.
Yes you are right, they are quater turn tap (had a read about it on the internet).
I read that i may need to replace the catridge. I still cannot figure out how to take it out.
Many thanks again for your help.
 Post subject:
PostPosted: Sat Jul 04, 2009 6:56 am
Take the screw out and tap the lug with the plastic end of a screwdriver or something similar, it's just a bit tight on the splines.
 Post subject:
PostPosted: Thu Jul 16, 2009 12:02 pm
Dear all,
thanks for all of your reply. I have tried all your methods, tap it with screwdriver, seems to making it worst.
I will try to buy another mixer tap now. To replace it i have to turn off the hot water supply.
I have another question with regard to the hot water supply. I cannot turn the hot water supply off. I am unable to locate the tap for hot water supply to turn it off.
We have a ecoTEC combi boiler.
Any advice apart from getting the local plumber out?
many thanks.
 Post subject:
PostPosted: Thu Jul 16, 2009 12:06 pm
OAP
Turn the cold mains off and the hot will stop as well.
