It is currently Sun Apr 21, 2019 5:22 pm
PostPosted: Sun Mar 24, 2019 11:23 am
Hi, I hope someone can help me. I am trying to replace a faulty toilet valve, weve moved house and the toilet is constanly refilling and making a hissing noise. Its a valve type ive not seen before and im struggling to find one like it online. Any chance someone can assist with identifying it?
Thanks in advance
PostPosted: Sun Mar 24, 2019 12:07 pm
Has thanked: 17 times
Been thanked: 102 times
I would say google flomasta or fluidmaster and look at the images, any of those should do the job.
PostPosted: Sun Mar 24, 2019 2:28 pm
Has thanked: 32 times
Been thanked: 26 times
As above but could be outdated old models, take pics and mail them.
PostPosted: Sun Mar 24, 2019 5:43 pm
Has thanked: 141 times
Been thanked: 173 times
Before you try and replace the valve, have you had a look at the washers inside the screw in parts? It may be just a case of replacing those. Probably a top hat washer that has perished.
Mike
PostPosted: Sun Mar 24, 2019 5:46 pm
They look like this
https://images.app.goo.gl/ocH4mU69237gwDMo6
Mike
PostPosted: Sun Mar 24, 2019 8:49 pm
Has thanked: 81 times
Been thanked: 192 times
With this type of valve, the internal parts that are prone to need attention are basically standard, buy the replacement washers from any diy store and replace them yourself. It does not need a new complete valve, and even it it did, any equivalent would do the job.
PostPosted: Mon Mar 25, 2019 10:46 am
Been thanked: 51 times
1. Turn off the water to the inlet of the cistern. With luck, there will be an isolation valve in the pipe below the cistern leading to the inlet valve. If not, find another way.
2. Disconnect the white plastic arm coming from the centre of the valve, turning a right angle and joining the threaded rod.
3. Unscrew the large white plastic nut with finger grips at the centre of the valve. The nut facing the left hand side of the cistern.
4. Remove the rubber diaphragm washer revealed when the nut is removed. Careful, there may be a stainless steel "needle" (sharp) through the centre of the diaphragm.
5. Take diaphragm to a plumber's merchant and get a replacement.
6. Reassemble in reverse of above.
For this message the author andy48 has received gratitude : arco_iris
PostPosted: Mon Mar 25, 2019 7:33 pm
Some people have too much time on their hands, to be able to type all that! Very helpful to OP, thanks Andy.
