It is currently Wed May 23, 2012 2:40 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 9 posts ]
 Post subject: Can i use chrome pipes
PostPosted: Thu Dec 01, 2011 2:57 pm
Has thanked: 4 times
Been thanked: 1 times
Hi can anyone tell me if it is ok to use chrome pipework for a basin sink waste and for 15mm pipe for water to the sink as I want that type of look in the toilet but dont know if its old fashioned and chrome isnt used anymore or if there is a reason, can someone give me a bit of advice, and also is it expensive :dunno:
PostPosted: Thu Dec 01, 2011 3:51 pm
Has thanked: 2 times
Been thanked: 61 times
I've used chrome for exposed pipework, you have to 'de-chrome' it to solder.
One of the older chaps like Scruffie, TomPlum or Dickie will be able to advise on tricks how to do it.
John
PostPosted: Thu Dec 01, 2011 4:14 pm
OAP
Has thanked: 187 times
Been thanked: 2110 times
Yes it's still used, mostly with compression fittings in posh pads.
You'll need to ensure you get chrome on copper, and PTS is probably the best outlet but shop around for best price if cost is a consideration.
Nickel is more popular now than chrome.
PostPosted: Thu Dec 01, 2011 9:45 pm
Has thanked: 11 times
Been thanked: 69 times
I've never liked chrome, if you want to solder it you have to file off the chrome, very laborious and time consuming, other wise you need chrome compression, very costly and bulky and untidy looking, I always find, and definitely never use pushfit on chrome, it will wait till you go out, then the fitting will blow off, but there's no reason other than price and looks, if you want it, go for it, each man to his own, :thumbleft:
PostPosted: Fri Dec 02, 2011 1:23 am
OAP
We have a unit in Bristol were we can fabricate the copper tube then they will chrome or nickel it
PostPosted: Fri Dec 02, 2011 2:29 pm
ok cheers guys, it doesnt sound as easy as I thought it would be. Just going back to the drawing board :roll:
PostPosted: Fri Dec 02, 2011 2:36 pm
OAP
It is very easy and very expensive. if you can plan it so the connections are hidden, you can use normal compression fittings or even solder if you clean the chrome off.
I mention chrome on copper as it can be bent using a bender if good quality.
PostPosted: Fri Dec 02, 2011 8:05 pm
Has thanked: 24 times
Been thanked: 70 times
To be posh in an under sink storage unit, I once used 15mm chromed to chromed isolation valve to chromed 10mm tails and after a year there is black/green copper dust residue and the chrome is peeling-some sort of galvanic action! :dunno:
PostPosted: Tue Dec 06, 2011 1:25 pm
copper won the day and will box in instead cheers tho guys :thumbright:
Users browsing this forum: Bing [Bot] and 0 guests
