www.ultimatehandyman.co.uk Forum Index -> Plumbing Forum
-> Central Heating & Boilers |
| Author |
Message |
Bella Junior Member
Posted: Sat Sep 27, 2008 5:20 pm Post subject: Can I change the radiator? |
Real idiotic question coming up.
We have had problems with a radiator in the hallway for ages now. It's leaking from the bottom. Not the pipes but the actual radiator. I had assumed it was the pipes. I gather I need a new radiator.
It's 96cm wide by my measurements. I measured from the radiator sides, not the pipe work. Do I round this up to 100cm?
Next dense question. Below is the radiator installed. Can I change it to the radiator in the link below that?
http://www.plumbworld.co.uk/duratherm-single-convector-2001-16895
Is this a difficult procedure? I am going to guess it will never be as easy as take off the old one and put on the new one. |
| Back to top |
Bludall Senior Member
Joined: 11 Apr 2007 Posts: 8556 Location: East Midlands
| Back to top |
thescruff Senior Member
Posted: Sat Sep 27, 2008 5:29 pm Post subject: |
Yes you could change it for the one in the link or the stelrad compact K1.
In either case you will have to drain down and alter the pipes one end, so how easy depends on your plumbing skills, perhaps a couple of compression elbows wouldn't look to bad. _________________ Scruff |
| Back to top |
Tryanything Senior Member
Posted: Sat Sep 27, 2008 10:44 pm Post subject: |
Scruff
Is it not posible to use valve extensions and use a 900mm wide radiator to save altering pipework ? _________________ SILVER---------HOG |
| Back to top |
Posted: Sat Sep 27, 2008 10:48 pm Post subject: |
I think one pipe maybe on the skirting looking at the pic. but yes you could do that if you needs be. _________________ Scruff |
| Back to top |
