It is currently Fri Feb 23, 2018 2:13 pm
Visit Thermo worx
Post new topic Reply to topic  [ 18 posts ]  Go to page 1, 2  Next
PostPosted: Fri Jan 06, 2017 10:39 pm
Been thanked: 1 times
Hi, Considering Honeywell Evo Home for new combi boiler, rads. pipes all new system being fitted.
I can have each radiator with different temperatures at different times of the day and different days programmed in.
If I wish to drop the temperature throughout the house by e.g 1 degree on all rads can I easily do this 'en-masse' in one click ?
If I wish also to have that drop applying to next day, can that be done in one click ?
I dont want to have to alter each degree setting for several rads
BOBC
PostPosted: Fri Jan 06, 2017 10:56 pm
Has thanked: 38 times
Been thanked: 1182 times
Hi, have you read the "blurb" about the kit? I had never heard of it, and I found THIS for you via google.
PostPosted: Sat Jan 07, 2017 2:49 am
yes , I am not seeing such answers to my question though.
Its all a bit general,
BOBC
PostPosted: Sat Jan 07, 2017 11:46 am
Has thanked: 11 times
Been thanked: 56 times
Do you mean trv's, thermostatic radiator valves.
PostPosted: Sat Jan 07, 2017 11:35 pm
BOBC01, did you read the PDF file? :wink:
PostPosted: Sun Jan 08, 2017 4:14 pm
Has thanked: 25 times
Been thanked: 133 times
Did you mean the Evohome User Guide?
According to that you can easily drop the temperature by 3C (page11); you may be able to change the drop to whatever you want (page 15). One of the Evohome experts on the forum should be able to confirm this.
PostPosted: Sun Jan 08, 2017 7:41 pm
Exactly as above. Evohome has an economy mode that drops all target temperatures and will stay in that mode until you take it out again. Default temperature drop is 3 degrees but you can reconfigure it to 1 degree if you want.
PostPosted: Mon Jan 09, 2017 5:05 pm
That is great news yet no one assoc with Honeywell evo home could tell me that and but for this reply I was about to reconsider.
That ability is going to make great savings on days with high moisture content .
BOBC01
PostPosted: Mon Jan 09, 2017 5:15 pm
BOBC01 wrote:
That ability is going to make great savings on days with high moisture content.
So you turn the thermostat down when it's raining? Please explain the logic.
PostPosted: Mon Jan 09, 2017 10:24 pm
Can do, this wont apply to all folk, some like hot kitchens steam rising from pots and pans on stove, I get out of such places in seconds. I prefer cooler temperatures in high water content environments. Leisure Centres for me always feel 'close' and stifling. When more moisture in air, the same temperature in the room as when a fresh air makes it feel oppressive muggy, uncomfortable, rather than open a window and drop the temperature, I aim to drop the gas being burnt, tell it to go for 1 or 2 degrees less than normal that day, trouble is a thats a couple of hrs of gas already burnt before I clambered out of bed and more than needed was already burnt, at least rest of day will be more comfortable and gas saved. Consult weather forecast to see if next day to continue on this high water content , if so apply temperature offset that day as well. Aim is to feel same level of comfort, so fresh and 23 = high water content and 21 and gas saved. It will work for me, and without being told, some others wouldn't notice a difference either. Quite a high proportion of my friends agree as they share the 'feeling' of high temperature not good with high water content in air.
BOBC01
For this message the author BOBC01 has received gratitude : D Hailsham
PostPosted: Mon Jan 16, 2017 11:18 pm
NJackson said...
Hi can you talk me through the steps on screen to do this as I cant see them.
Cheers
BOBC01
PostPosted: Tue Jan 17, 2017 11:14 am
You need to go to Settings/Quick Actions/Economy.
PostPosted: Tue Jan 17, 2017 8:35 pm
Hi, I have done that already, but I dont then see where one can alter the 3 degrees to 1 degree or 2 degrees.
BOBC01
PostPosted: Sat Jun 17, 2017 5:29 pm
I am still awaiting please a reply as to exactly where one sets the economy to 1 degree.
NJackson you said its possible, where is this to be done ?
BOBC01
PostPosted: Sat Jun 17, 2017 6:58 pm
NJackson has "left the building" his last post was in reply to you on Jan 8th.
