-> Carpentry/Joinery Forum |
| Author |
Message |
Hitch Senior Member
Posted: Mon Oct 29, 2007 7:31 pm Post subject: Camper van |
Been asked to fit out a camper van, some overhead cabinets, storage spaces/bench seats, shelving unit etc.
Im at a bit of a loss what to use. Thinking about 9mm/12mm mdf, painted, but hed prefer wood. Hes thinking about using just 'pine' (wickes softwood ) I was thinking perhaps that in something like that it may not be as stable as perhaps it should be?
I want something that can rout, cut shape readily, without having to trim/bead many edges.
Any thoughts? _________________ Why isn't the number 11 pronounced onety one? |
| Back to top |
Wood Magnet Senior Member
Posted: Tue Oct 30, 2007 1:12 am Post subject: |
The only time i've fitted a van out was with
ply, but thats what he wanted. What about
t&g that would rout or jigsaw easily.  _________________ People forget how fast you did a job - but they remember how well you did it.
I no longer skinny dip, i chunky dunk these day's. |
| Back to top |
Tryanything Senior Member
Posted: Tue Oct 30, 2007 9:49 am Post subject: |
Hi Hitch
Why not try veneered MDF and iron on edging _________________ Tony Tiger |
| Back to top |
big-all Pro Carpenter
Joined: 16 Dec 2006 Posts: 2775 Location: redhill surrey an auld reekie laddie
Posted: Tue Oct 30, 2007 1:03 pm Post subject: |
in general weight is an issue they tend to use 4mm ply but you should opt for 6 or9 with 12 for horizontal surfaces
if its a seated area you should consider 12mm for side pannels and 18mm for horizontal then you wont need a frame for support
fixing to the bodywork can be a pain is it lined or ribbed[stantions] bodywork!!!!!
try and plan for things to have 2 or more uses like table for example fits between benches to make a sleeping area
doors should be sliding or not protrude to far when open
finger holes or very small round knobs are preferable
solid bolts or latches are preferable to hold doors shut
need any more ideas just shout  _________________ we are all ------------------still learning |
| Back to top |
Hitch Senior Member
Posted: Tue Oct 30, 2007 5:39 pm Post subject: |
Well, we are going for a paint finish MDF to keep it simple.
Perfect Bigall, thats what i told him to get, 6 and 12mm mdf  _________________ Why isn't the number 11 pronounced onety one? |
| Back to top |
Hitch Senior Member
Posted: Thu Nov 01, 2007 6:16 pm Post subject: |
Some 4mm ply too going in.
Seems he wants to bodge new frontages on, and not bother altering any frameworks  _________________ Why isn't the number 11 pronounced onety one? |
| Back to top |
Posted: Thu Nov 01, 2007 7:15 pm Post subject: |
just be carefull and try and source your materials from other than a caravan /camper suppler/spares shop as they are up to 3 times the price  _________________ we are all ------------------still learning |
| Back to top |
Hitch Senior Member
Posted: Thu Nov 01, 2007 7:19 pm Post subject: |
Timber etc from Wickes, theres only a few proper campy type bits to replace, hes already got them now.
| Back to top |
Posted: Thu Nov 01, 2007 7:26 pm Post subject: |
also remember if you replace a pannel with a thicher spec check for clearence as clearences are often very tight
as in replace a 6mm door panel with 9mm the door won't fully open because the adjoining door is only 7mm away  _________________ we are all ------------------still learning |
| Back to top |
ultimatehandyman Site Admin
Posted: Thu Nov 01, 2007 10:18 pm Post subject: |
Where is Knoba when you need him
He did some good work on a camper van. _________________ DIY | DIY Video |
| Back to top |
Mr Mike Junior Member
Joined: 22 Jul 2007 Posts: 44 Location: Greenwich, London
Posted: Fri Nov 02, 2007 8:16 am Post subject: |
I must admit I would've gone for ply.
If you're going to use MDF, try and get Moisture Resistant, not only will it be more practical....but routs and cuts more cleanly.....  |
| Back to top |
Hitch Senior Member
Posted: Fri Nov 02, 2007 7:24 pm Post subject: |
Cheap job is what he wants. Would have been nice to rip it all out and start afresh. Instead hes keeping some of the frames for benches/beds and just putting on a new fronts. Same in the kitchen area, just new fronts and doors built around the botched framework.  _________________ Why isn't the number 11 pronounced onety one? |
| Back to top |
