It is currently Wed May 23, 2012 2:27 am
 Post subject: Cable Size
PostPosted: Fri Jan 13, 2012 9:44 am
Has thanked: 21 times
Advanced apology for the somewhat dumb question :roll:
I am having a new electric hob and oven fitted as part of a kitchen re-fit. The total power requirement for the two units will be around 10kw.
I have looked at the internet etc as to the size of the cable needed for two units and they mention that it will be need to be 16mm or so. I assume it does not mean diameter of the cable that would be huge! :scratch:
What exactly does this size mean ?
 Post subject: Re: Cable Size
PostPosted: Fri Jan 13, 2012 9:53 am
Has thanked: 166 times
Been thanked: 611 times
Depending on the Kw rating of the oven, it may be possible to run the oven from a 13 A ring, and the Hob from a Radial.
If running both from the same cable, I'd suggest 10mm csa, as 6mm will not allow for a great margin of safety.
PostPosted: Fri Jan 13, 2012 10:57 am
Has thanked: 62 times
Been thanked: 217 times
The cable size refers to the 'cross-sectional area' of the individual cores. In other words the 'area' of a circle. A 16mm cable has an individual core diameter of 'about' 4mm.... plus more for the core covering and again some more for the sleeving. It ends up about 12mm x 6mm (oval shaped) for twin+earth.
This post may contain nuts
cron
