Ultimate Handyman Home
Cable run unclipped
Post new topic   Reply to topic   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Electric Forum UK
barrym
Junior Member
PostPosted: Sun Oct 12, 2008 1:58 pm    Post subject: Cable run unclipped Add User to Ignore List Reply with quote
Is it permissible to run T&E cables on the top side of a plaster ceiling without clipping to the joists? They will be protected by an RCD.
Cheers,
Barry
Back to top
IDontBelieveIt
Approved Electrician
PostPosted: Sun Oct 12, 2008 2:28 pm    Post subject: Add User to Ignore List Reply with quote
Hi
To be exact no. To be realistic yes. Hope that answers your query.
Never lie - that way you don't have to remember what you said.
Back to top
barrym
Junior Member
PostPosted: Sun Oct 12, 2008 4:45 pm    Post subject: Add User to Ignore List Reply with quote
...Thanks for that. Yes, of course to clip it means dismantling the floor to get at the joists.
Could you point me to the regulation that says the cables have to be clipped please?
Barry
Barry
Back to top
IDontBelieveIt
PostPosted: Mon Oct 13, 2008 4:06 pm    Post subject: Add User to Ignore List Reply with quote
I can but not right now as I don't have the regs with me they are at home.
Cables should not be left un-supported for more than 1 meter, which is another reason why it is bad practice and against the regs to drop cables down cavities.
If I recall the clipping should be every 200 mm.
When it comes to lofts most sparkys leave cables unclipped, does not make it right but it is a LOT more convenient when it comes to things like the installation of rockwool and when boarding out loft spaces.
Back to top
IDontBelieveIt
PostPosted: Mon Oct 13, 2008 6:17 pm    Post subject: Add User to Ignore List Reply with quote
522.8.4 and 522.8.5 (17th) applies.
Back to top
Display posts from previous:
Post new topic   Reply to topic    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Electric Forum UK All times are GMT
Page 1 of 1
