Ultimate Handyman Home
BURYING HOT AND COLD PIPES FOR THERMOSTATIC SHOWER
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plumbing Forum
diymark
Junior Member
PostPosted: Fri Jul 06, 2007 12:09 pm    Post subject: BURYING HOT AND COLD PIPES FOR THERMOSTATIC SHOWER Add User to Ignore List Reply with quote
Hi everyone,
I'm in the midst of installing a new bathroom suite and thermostatic shower.
So far, new bath and basin are in. I now at the stage where I am going to chase walls for hot and cold pipe for a thermostatic shower.
Up to now all pipework is pushfit.
Should I use pushfit tubing for shower?
Can I bury it and then plaster over?
Is copper pipe better or does the plaster ruin the copper
How deep do I have to chase wall?
Simplest and easiest way to chase wall?
The thermostatic shower is quite heavy. How do I secure it properly?
Any other advice welcome!
Thank you.
Back to top
Jaeger_S2k
PostPosted: Fri Jul 06, 2007 12:41 pm    Post subject: Add User to Ignore List Reply with quote
Is this an over bath shower or a separate unit?
Have you got or can you take some pics of the install area showing existing structures and clearances?
Jaeger.
FSBF
Back to top
diymark
Junior Member
PostPosted: Fri Jul 06, 2007 3:50 pm    Post subject: Add User to Ignore List Reply with quote
Thank you for your reply.
The shower is a seperate unit.
I will try to get some photos.
However, at the moment I have a blank canvas.
I have a wall which which the old bath used to sit in front of. This wall is where the shower cubicle is going, in the middle of the wall.
Regards,
Mark
Back to top
Hinton Heating
Gas/Heating Expert
PostPosted: Fri Jul 06, 2007 4:13 pm    Post subject: Add User to Ignore List Reply with quote
copper will need protecting from corrosive mortar, and plaster.
Plastic is fine to bury, just dont bury any fittings.
Some of the choices will depend upon the shower itself, and how it fixes to the pipes
www.hintonheating.com
Back to top
Jaeger_S2k
PostPosted: Fri Jul 06, 2007 4:23 pm    Post subject: Add User to Ignore List Reply with quote
0:a
You also want to have a look at Tanking.
Do a search and have a read.
Fixing shouldn't be a problem your mixer will probably have a bracket to secure to the wall, then the mixer fixes to the bracket.
Jaeger.
FSBF
Back to top
diymark
Junior Member
PostPosted: Tue Jul 10, 2007 11:45 am    Post subject: Add User to Ignore List Reply with quote
Thanks so much for the advice- really appreciated
Regards,
Mark.
Back to top
Jaeger_S2k
PostPosted: Tue Jul 10, 2007 12:04 pm    Post subject: Add User to Ignore List Reply with quote
Oh and if you plan ahead you can pit a noggin in across between two uprights and it'll give you a solid to screw the valve retainer to.
Jaeger.
FSBF
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plumbing Forum All times are GMT
Page 1 of 1
