It is currently Wed May 22, 2019 10:02 am
PostPosted: Tue Nov 20, 2018 11:23 am
Hi, posting for the first time here and thank you to anyone who reads/advises on this.
We have a laminate kitchen countertop, which has some burn marks due to a hot utensil being placed on it. I am trying to fix this so that the entire kitchen countertop does not need replacement. Any ideas would be welcome!!!
Thanks for your help,
Ro
PostPosted: Tue Nov 20, 2018 11:40 am
Has thanked: 45 times
Been thanked: 759 times
Not a lot you can do really. You will never hide it but if you want to stop the laminate lifting then you would drill out the affected area and fill with a coloured resin. You can't do any of the repairs designed for solid wood or composite tops, it's the trade off for laminate.
PostPosted: Tue Nov 20, 2018 12:06 pm
Has thanked: 416 times
Been thanked: 1565 times
Don't know if you can still get them, (they were never popular) but you can get an inset cutting board which would be ideal if the burns are in an appropriate place - they are usually also heat tolerant so can be used to put hot pans on too which is the source of the original problem.
Otherwise just put a cutting board/mat/whatever over the burns to hide them, (there's no way to repair laminate without it showing).
PostPosted: Tue Nov 20, 2018 12:12 pm
Has thanked: 659 times
Been thanked: 1875 times
I was thinking https://www.dunelm.com/product/black-gr ... 1000009315
Following on from what Ayjay has said, this could be routered in and set into the worktop or just lay it on flat to hide the burns.
Painting with BIN
PostPosted: Tue Nov 20, 2018 12:30 pm
Thanks for the advice. Sounds like sticking a worktop saver on it is a good idea. I think i might use this
https://www.amazon.co.uk/dp/B078SZRT1F/
One more follow up. Any advice on how to stick it on the countertop? I want to stick it clean so at least it does not spoil the look of the kitchen and also doesnt ruin the laminate if i decide to take it off. But need something which will stick glass to laminate...
any ideas on this?
PostPosted: Tue Nov 20, 2018 12:35 pm
That will do it you do not need to stick it down as they have rubbery feet that stop slip. Alternatively router a shallow rebate into the worktop and drop it in flush to the surface, a bit more like it was designed that way.
Painting with BIN
PostPosted: Tue Nov 20, 2018 10:23 pm
Old School Chippie
Has thanked: 808 times
Been thanked: 1616 times
rohitiiml wrote:
.... But need something which will stick glass to laminate...
any ideas on this?
Try MirrorMate. I've used it (a lot) to adhere stainless steel onto old tiles - although it did need the tiles to be thoroughly degreased first (Sugar Soap solution) as well as fix mirrors onto everything from plastered walls to gloss painted doors and a lot more besides (including laminated doors - so yes it can.....). One word of caution; MirrorMate is quite dense and so it is best applied using a heavy-duty caulking gun rather than a basic, lightweight skeleton gun
PostPosted: Tue Nov 20, 2018 11:45 pm
Has thanked: 710 times
Been thanked: 2043 times
personally i would avoid routering the surface unless the cover has at least a 6mm lip all the way round
otherwise it has to be very exact shape with no gaps
also old laminate especially subject to high temperatures is far more likely to chip and de laminate often in big chunks :cb
