-> Plumbing Forum |
| Author |
Message |
tpwuk Member
Posted: Thu May 01, 2008 10:07 pm Post subject: Broken Draincock/Spigot |
The draincock/spigot at the bottom of my hot water cylinder appears to be broken. It just turns and turns and doesn't open. I think I may have over tightened it! So basically I can no longer drain my hot water cylinder should I need to.
Has anyone come across this problem before? It it repairable without replacing it?
Cheers,
Glenn |
| Back to top |
thescruff Senior Member
Posted: Thu May 01, 2008 10:27 pm Post subject: |
No need to be embarassed it's a common problem, or to be exact the washers stuck.
What you do about it depends on the nerves or not as the case may be.
turn the DC off then open it one full turn, tap the end of the square bit it may free it, if not open it one more turn and try.
Leave the cold feed turned on to give extra pressure an don't forget the hose pipe.
If that fails you can insert a thin screwdriver in the spout and ease the washer forward, but you have to be quick with the hose.
Final choice is to siphon the water out through the top or the cold feed by removing the valve.
Don't forget to turn the immersion off in the excitement _________________ Scruff |
| Back to top |
tpwuk Member
Posted: Fri May 02, 2008 6:35 am Post subject: |
| Is it just a rubber washer in there then? |
| Back to top |
Posted: Fri May 02, 2008 7:50 am Post subject: |
Yep exactly the same as a tap _________________ Scruff |
| Back to top |
