It is currently Tue May 22, 2012 10:44 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 2 posts ]
PostPosted: Fri Nov 04, 2011 10:25 am
Has thanked: 5 times
Been thanked: 1 times
Hi all,
Not sure if this is the right place for this, so apologies if it is wrong & please move to right section if so.
Anyone know anything about these?
Ours just flashes the Start/Stop light & does nothing else.
Won't run any cycles or anything.
Just flashes the Start/Stop light.
I have had it apart & re-seated all the connections inside.
Also had the back off & tried the red reset button, just incase it was that, but it didn't really click & has not solved the problem.
We have also cleaned all the grey fluff out of it & it still doesn't work.
Gonna take the pump out & give that a good clean in a bit to see if that helps.
It's a bit specific, I know, but does anyone have any other ideas I can try.
Many thanks,
Pete
PostPosted: Fri Nov 04, 2011 1:33 pm
Hi all,
Just to let you know, it is now fixed.
I took the left-hand side (as you look at it front on) off the dryer & took the plastic shield off the pump.
One of the connectors had risen a bit.
When I pushed on it, it went down about 5mm.
I also cleaned some grey fluff from inside part of door & underneath the door moulding inside the machine.
Put it all back together.
Switched it on, then to cupboard dry.
The Start light came on much quicker than it was.
I pushed the Start button & it started to spin as normal.
Maybe this will help others if they have similar problems.
Thanks again,
Pete
For this message the author Pete_2011 has received gratitude : ultimatehandyman
Users browsing this forum: No registered users and 10 guests
