Ultimate Handyman Home
Bonding or Hardwall?
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plastering Forum
pmg
Member
PostPosted: Thu Aug 02, 2007 4:26 pm    Post subject: Bonding or Hardwall? Add User to Ignore List Reply with quote
I should probably know this but I will ask the forum anyway.
Whats best for going over or covering up old bricks?
Straight hardwall? Or bonding with pva applied first?
Back to top
tim'll fix it
PostPosted: Thu Aug 02, 2007 6:14 pm    Post subject: Add User to Ignore List Reply with quote
british gypsum do a guide as to what to use where
http://www.british-gypsum.bpb.co.uk/PDF/LIT_Thistle%20Plaster%20DL-Jan05.pdf
Decking
Back to top
andy-p-
pro plasterer
PostPosted: Thu Aug 02, 2007 6:20 pm    Post subject: Add User to Ignore List Reply with quote
Hardwall
Back to top
pmg
Member
PostPosted: Fri Aug 03, 2007 9:16 am    Post subject: Add User to Ignore List Reply with quote
Cheers for that
The job does involve covering up some plastic pipes aswell which I will probably use expanding foam to cover up first. So is hardwall ok over that too?
Back to top
john59
PostPosted: Fri Aug 03, 2007 10:58 pm    Post subject: Add User to Ignore List Reply with quote
Yes Thumbright
Back to top
Parentstoolbox
Junior Member
PostPosted: Tue Aug 14, 2007 4:30 pm    Post subject: Add User to Ignore List Reply with quote
What is hardwall?
Is it just sand and cement mix?
Back to top
andy-p-
pro plasterer
PostPosted: Tue Aug 14, 2007 5:05 pm    Post subject: Add User to Ignore List Reply with quote
its a backing coat plaster for brick or block.
http://www.british-gypsum.bpb.co.uk/products/thistle_plaster_products/thistle_undercoat_plasters/thistle_hardwall.aspx
Back to top
Parentstoolbox
Junior Member
PostPosted: Tue Aug 14, 2007 5:06 pm    Post subject: Add User to Ignore List Reply with quote
Julian
Back to top
nearnwales
Junior Member
PostPosted: Fri Aug 17, 2007 11:14 pm    Post subject: Add User to Ignore List Reply with quote
no its not its a backing coat for stone !
Back to top
View user's profile Send private message Yahoo Messenger MSN Messenger
andy-p-
pro plasterer
PostPosted: Sat Aug 18, 2007 7:21 am    Post subject: Add User to Ignore List Reply with quote
its a backing coat for most masonry backgrounds!
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plastering Forum All times are GMT
Page 1 of 1
