| Author |
Message |
Benj
Posted: Wed Sep 30, 2009 5:08 pm |
| Newly registered Member |
Joined: Wed Sep 30, 2009 5:04 pm Posts: 12 Has thanked: 0 times Been thanked: 0 times
Hello all. I have a baxi boston 2 60-rs and never had any problems up until recently. For the first time my gas ran out (i forgot to top up) and ever since then my boiler wont kick in. I can light the pilot light no problem and it stays on, the pump above is still spinning and eveything seems normal apart from that. Im thinking it must be something minor for it to be ok one minute, then gas cut off and now it wont boot up. And yes, i have put more gas back on! :p
Thanks in advance if you could advise. Cheers.
| Top |
thescruff
Posted: Wed Sep 30, 2009 5:21 pm |
| OAP |
Joined: Mon Mar 10, 2008 12:46 am Posts: 39966 Has thanked: 187 times Been thanked: 2110 times
Has the grey knob come right out.
Turn the boiler thermostat to off and wait 3 mins to reset the valve, and it should work.
It will click when ready.
_________________ If you feel you have benefited from the Free advice given on the Forum, Please consider making a donation to UHM's Nominated charity, read all about it and donate here : donnas-dream-house-charity-t52110.html
| Top |
register or
log in
Benj
Posted: Wed Sep 30, 2009 5:31 pm |
thescruff wrote: Has the grey knob come right out.
Well it hadnt, i didnt notice that! I'v pulled it out now and put the thermostat to off, just waiting now for it to "click" Not heard anything yet?
Cheers.
| Top |
register or
log in
Benj
Posted: Wed Sep 30, 2009 5:48 pm |
It's still not clicked after about 10minutes. I'v tried turning the thermostat but still with no joy...:(
Any other ideas?
| Top |
register or
log in
thescruff
Posted: Wed Sep 30, 2009 6:13 pm |
| OAP |
Is the pilot alight
Turn the thermostat to off, and light the pilot, after 3mins turn the thermostat up and it should work.
| Top |
register or
log in
Benj
Posted: Wed Sep 30, 2009 6:46 pm |
thescruff wrote: Is the pilot alight  Turn the thermostat to off, and light the pilot, after 3mins turn the thermostat up and it should work.
yeah mate it is. Tried it a few times and still no joy, arrg! :(
| Top |
register or
log in
thescruff
Posted: Wed Sep 30, 2009 7:15 pm |
| OAP |
Ok try it another way.
Turn the stat to off, then turn the grey knob to extinguish the pilot.
Wait 3-4 mins and relight the pilot, make sure the knob comes right out.
| Top |
register or
log in
gas4you
Posted: Wed Sep 30, 2009 8:03 pm |
| Senior Member |
Joined: Mon Apr 13, 2009 8:03 pm Posts: 3574 Has thanked: 51 times Been thanked: 230 times
I assume this is on LPG?
If so go and check your UPSO at the regulator
_________________ Dave
www.drlgas.co.uk
| Top |
register or
log in
Benj
Posted: Wed Sep 30, 2009 8:19 pm |
Tried the alternative way, still nothing :(
I dont know if it is LPG or not..What is the UPSO ? And where is the regulator? Im a complete novice at boilers etc :s
Thanks in advance!
| Top |
register or
log in
thescruff
Posted: Wed Sep 30, 2009 8:20 pm |
| OAP |
gas4you wrote: I assume this is on LPG?
Don't think they made the Boston for LPG Dave.
I took it to read the pre-payment card had run out.
| Top |
register or
log in
thescruff
Posted: Wed Sep 30, 2009 8:21 pm |
| OAP |
Benj wrote: Tried the alternative way, still nothing :(
Thanks in advance!
Is it mains gas or bottled/tank gas
| Top |
register or
log in
Benj
Posted: Wed Sep 30, 2009 8:26 pm |
thescruff wrote: Benj wrote: Tried the alternative way, still nothing :(
Thanks in advance! Is it mains gas or bottled/tank gas
It is a mains gas
| Top |
register or
log in
thescruff
Posted: Wed Sep 30, 2009 8:30 pm |
| OAP |
Give the gas valve a gentle tap with a hammer handle.
And don't whack it, or you'll need a new one
| Top |
register or
log in
Benj
Posted: Wed Sep 30, 2009 8:33 pm |
thescruff wrote: Give the gas valve a gentle tap with a hammer handle.
Which is the gas valve? lol. Iv already got gas running you see through the cooker and i imagine the boiler as the pilot light stays lit?
Thanks in advance
| Top |
register or
log in
thescruff
Posted: Wed Sep 30, 2009 8:37 pm |
| OAP |
Yes but the main valve isn't opening.
Are you sure the electric is turned on and programed to work
Turn it all on to 24hrs.
| Top |
register or
log in
