It is currently Thu Apr 25, 2019 9:38 am
 Post subject: Boiler firing up issues
PostPosted: Fri Sep 14, 2018 1:39 pm
Hope you can help steer me in the right direction for this fault.
So I have a gravity fed heating system, with a Potterton Profile boiler, Drayton Lifestyle L711 Programmer and Drayton Combi-stat.
(Also Honeywell 3 port valve).
This has all been working well, however have had it switched off over the summer and when I've switched it back on the following happens:
Press Heating on button alone (on Drayton Programmer) = boiler does not fire up
Press Hot water on button alone = boiler does not fire up
Press both on together = boiler does not fire up
Switch either of them off (when set to on but boiler not firing) = boiler instantly fires up (every time)
Then I am able to switch the other one on and both heating and hot water work perfectly until they are turned off.
Just trying to diagnose if this fault lies with the programmer or boiler?
Hope someone may have seen this fault before and be able to advise?
Many thanks
PostPosted: Fri Sep 14, 2018 6:30 pm
Has thanked: 41 times
Been thanked: 1470 times
Flip it on its head. :shock:
A boiler will only come on when its told to.
Since your boiler is working (ok, its working but at the wrong time) I can not see it being the boiler.
It has to be something to do with the controls, what, i have no idea.
Have you changed anything to with the boiler or its controls? any thing? new batteries? blown fuse, took it off to paint round it? anything?
PostPosted: Fri Sep 14, 2018 6:43 pm
Thanks for your help...
I was hoping it was potentially the programmer and not the boiler.
We haven't changed anything to do with the boiler or its controls.
We've not moved it or even touched it since we turned it off for the summer (used the immersion in the summer for hot water) - might have been wise to try it at some point!
Perhaps we could start by trying a new programmer, might be the cheapest place to start anyway?!
Thanks very much
PostPosted: Fri Sep 14, 2018 8:42 pm
Before you do that, what happens if you down power your programmer / factory default it? (You have nothing to lose) It may have even defaulted itself and needs setting up?
PostPosted: Sat Sep 15, 2018 12:39 pm
Thanks very much
Tried all resets we can find this morning and still doing the same thing.
We are going to order a new programmer and try that, unless anyone else has any thoughts?
PostPosted: Thu Sep 20, 2018 8:18 pm
Just to finish this post - a new programmer worked and solved the problem.
