Ultimate Handyman Home
Boiler ON/OFF/ON/OFF
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plumbing Forum -> Central Heating & Boilers
mells
Junior Member
PostPosted: Wed Oct 24, 2007 4:00 pm    Post subject: Boiler ON/OFF/ON/OFF Add User to Ignore List Reply with quote
Hi Guys, great forum!
I recently moved into a new house. It has a old school central heating system that works brilliantly but has a mind of its own. I'm at work at the moment so dont have any model numbers etc, but the system isnt a pressurised system. It has 2 tanks.
My problem is: From cold the bolier fires up, warms the house nicely, but when its warm the boiler will switch off for about 2 mins, then fire up again for about 30 secs, then go off again, does this all the time its on etc.
This obviously isnt very good and I dont suppose its doing the boiler any good either.
Any ideas?
My first thought was the thermostat. The system doesnt have any rad thermostats its all done by a very old looking stat in the living room. I've bled all the radiators recenly as there was some air rushing about.
Back to top
Jaeger_S2k
PostPosted: Wed Oct 24, 2007 4:27 pm    Post subject: Add User to Ignore List Reply with quote
It will need a service.
But the symptoms sound like some temperature monitors are goosed, an engineer will investigate the symptoms better than I can, Hinton Heating will be on later.
I'd say return temperature sensor isn't working and the boiler is monitoring the temp.
Jaeger.
FSBF
Back to top
Hinton Heating
Gas/Heating Expert
PostPosted: Wed Oct 24, 2007 5:57 pm    Post subject: Add User to Ignore List Reply with quote
seems the boiler stat may need replacing...
But it is quite common for old boilers to cycle on & off, once the system is up to temperture.
Modern boilers have anti-cyling devices built on the the PCB, because of this situation in old boilers.
www.hintonheating.com
Back to top
mells
Junior Member
PostPosted: Wed Oct 24, 2007 6:06 pm    Post subject: Add User to Ignore List Reply with quote
thanks guys,
Hindsight is a wonderful thing. I should have had the vendors service it before we exchanged. Lesson learned.
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plumbing Forum -> Central Heating & Boilers All times are GMT
Page 1 of 1
