Ultimate Handyman Home
boiler again
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plumbing Forum -> Central Heating & Boilers
Raylea
Junior Member
PostPosted: Sun Oct 21, 2007 7:34 pm    Post subject: boiler again Add User to Ignore List Reply with quote
Just posted about boiler will not ignite.
Come to think of it my other half was bleeding some radiators because they keep going cold at the top, now have we depressurized the boiler and should we have bleed them when they were not on. There is a pressure guage on our megaflo tank and that is flat, however I cannot see one on the boiler worcester r40. How do we put pressure back is by the filling loop that I have just read about. Plus we do have a few leaking rads.
Cheers Raylea Embarassed
Back to top
Hinton Heating
Gas/Heating Expert
PostPosted: Sun Oct 21, 2007 9:22 pm    Post subject: Add User to Ignore List Reply with quote
the leaking rads (valves) are causing air in your system. Yes use the fill loop to recharge to 1.3bar in the radiators
www.hintonheating.com
Back to top
Raylea
Junior Member
PostPosted: Mon Oct 22, 2007 7:53 pm    Post subject: Add User to Ignore List Reply with quote
Yep cheers, about 9.30 I had worked it out and all is good, plus we will sort out the leaky valves.
Cheers again Raylea Thumbright
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plumbing Forum -> Central Heating & Boilers All times are GMT
Page 1 of 1
