Page 1 of 1
[ 4 posts ] |
| Author |
Message |
goldfish_memory
Posted: Sun May 15, 2011 11:50 am |
| Newly registered Member |
Joined: Wed Nov 04, 2009 2:34 pm Posts: 14 Has thanked: 0 times Been thanked: 0 times
Hi Chaps,
I've gutted my living room, taken all the old blown plaster off the walls and am about to start sticking plasterboard up onto the walls. It being an old part of the house all of the walls are solid brick, even the internal ones, its left me a bit confused as to what to do around the door frame.
Currently the door frame is only very slightly proud of the brick work, so when I put the boards up and get a skim over they're going to stand proud of the door frame. Any tips as to how to deal with this, best I'm thinking of at the moment is just to get them where they're standing proud and butt the architrave up to the edge of the plastered wall at the end?
Cheers,
GM
| Top |
ayjay
Posted: Sun May 15, 2011 12:51 pm |
| Senior Member |
Joined: Wed Nov 17, 2010 5:51 pm Posts: 1000 Has thanked: 7 times Been thanked: 128 times
The purpose of the architrave is to cover the joint between the door lining and the plaster - the best method in your situation is to build out the door frame with a piece of prepared timber of a suitable thickness and dot and dab to the depth of the new timber - if you set the new piece of timber back about 3mm from the edge of the door frame it will all blend in when you fit the architrave and decorate.
_________________ One day it will all be firewood.
| Top |
register or
log in
goldfish_memory
Posted: Wed May 18, 2011 3:46 pm |
Seems really obvious now, thanks for the advice!
| Top |
register or
log in
cwplastering
Posted: Wed May 18, 2011 6:26 pm |
| Senior Member |
Joined: Thu Jul 09, 2009 7:01 pm Posts: 1777 Location: Peterborough Has thanked: 44 times Been thanked: 114 times
if its hinge side then make it a good un, screwed and glued cos if its only stopbead then the screws from the hinge will go bang through the join and it'll be loose.. sometimes easier to fit new door liners and put the plant all on one side or just wet plaster the hinge side.. firestop bead gives you loads of room though...
| Top |
register or
log in
Page 1 of 1
[ 4 posts ] |
