www.ultimatehandyman.co.uk Forum Index -> Plumbing Forum
-> Central Heating & Boilers |
| Author |
Message |
Hoovie Devon DIYer
Posted: Fri Oct 19, 2007 1:51 pm Post subject: Bleeding Rayburn DHW system - is there a need to? |
Will be shortly plumbing in my Gas-Fueled Rayburn.
System will comprise Rayburn 208G Cookmaster (Cooking and DHW only), pipeworking will be going to coil in Hot Water Tank, and a F+E tank will provide, well, F+E services.
There will be no Radiator acting as heat dump within the system and system is Gravity only, no pump.
Question is: Is this system essentially self-bleeding through the Expansion pipe over the F+E tank or do I add in some kind of bleed valve to get rid of any air? _________________ I went to a bookstore and asked the saleswoman, "Where's the self-help section?"
She said if she told me, it would defeat the purpose. |
| Back to top |
Hinton Heating Gas/Heating Expert
Joined: 16 Jan 2006 Posts: 4296 Location: Bournemouth
Posted: Fri Oct 19, 2007 5:22 pm Post subject: |
you only need to add an air bled, if you have a high point. _________________ www.hintonheating.com
| Back to top |
Hoovie Devon DIYer
Posted: Fri Oct 19, 2007 6:41 pm Post subject: |
the *intention* is to be rise once, then fairly level on the pipes, with slight inclines going to cylinder (on same floor as range) and bring in the expansion pipe at the high point, so that will take care of it, then.
Cheers, HH  _________________ I went to a bookstore and asked the saleswoman, "Where's the self-help section?"
| Back to top |
