It is currently Sun Jul 15, 2018 10:23 pm
 Post subject: BLEEDING KNOTS - WHY ?
PostPosted: Wed Sep 20, 2017 11:29 pm
Has thanked: 7 times
My skirting boards were treated with `knotting` approx. 4yrs ago & recently
noticed the knots have bled leaving brown marks: used water based primer/u.coat followed by 2 coats of water based `Crown Satin`. Any Pro - Decorators advise, Thankyou.
PostPosted: Thu Sep 21, 2017 9:44 am
CLOSED ACCOUNT
Has thanked: 900 times
Been thanked: 764 times
Depends how bad they are bleeding really. You could get away with scraping back the knot bleed, cleaning with meths and applying a coat or two of shellac based primer, ie Zinsser BIN.
Worse case scenario could involve applying heat to the knots and scraping back until all the resin has gone, and then applying the primer.
If they are just brown marks, touch up with the BIN and you should be OK to repaint.
Knots are a law unto themselves really, and even with a good few applications of knotting solution can bleed or stain through.
Sent from my SM-G850F using Tapatalk
For this message the author fitzy has received thanks - 2: Bolster, dynamod
PostPosted: Thu Sep 21, 2017 10:14 am
Elephant Man
Has thanked: 600 times
Been thanked: 1348 times
As fitzy says, but if you're applying heat to knots, wear safety specs, as I've seen resin pockets exploding/popping. Its rare, but stay safe.
Permanent solution is to drill out the knots and 2 pack fill them.
Nihil expectore in omnibus
For this message the author dynamod has received thanks - 2: Bolster, fitzy
Users browsing this forum: spottie and 2 guests
