It is currently Tue May 22, 2012 10:09 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 28 posts ]  Go to page Previous  1, 2
 Post subject: Re: Bleed Valve needed.
PostPosted: Wed Nov 23, 2011 11:20 am
OAP
Has thanked: 187 times
Been thanked: 2110 times
Have you got a 1/8 one to see whether the screw will fit the old one.
PostPosted: Wed Nov 23, 2011 11:54 am
Has thanked: 4 times
No I haven't but when I took mine into plumb centre and compared it to a 1/8bsp it was a lot different, there is no way a 1/8 will fit. I am fairly sure mine is an M7 thread believe it or not. Just got to get hold of an M7 bolt to try it.
PostPosted: Wed Nov 23, 2011 12:03 pm
OAP
I meant the bleed screw not the whole fitting.
PostPosted: Wed Nov 23, 2011 3:26 pm
Ah ok, sorry my mistake. That is the problem with the fitting I have, originally the bleed screw sheared off, I tried various methods to remove the bleed nipple starting with a small 'easy out', drill, etc but couldn't shift it, I eventually ended up with a knackered hole/thread where the bleed nipple goes. So the actual 'nut' part which I am after still screws into the radiator ok but I cant screw a bleed nipple into it. But, maybe the bleed nipple from a 1/8 or 1/4bsp fitting is larger which would enable me to tap out my existing fitting.... maybe?
PostPosted: Wed Nov 23, 2011 4:25 pm
OAP
Our friends at Myson have just replied, need the model type so I forwarded the pic.
Can you pm me an address for it to be delivered (in anticipation)
PostPosted: Thu Nov 24, 2011 8:55 am
OAP
Good morning Scruff,
Thank you for the attached.
We hold the bleed screw you require in our sales office. We will arrange for 3x to be posted today for you and you will receive these in the next few days.
We hope this helps.
Kind regards
ps.
I'll pass them on when they arrive
For this message the author thescruff has received gratitude : Cookie
PostPosted: Thu Nov 24, 2011 9:57 am
:cheers: :cheers: :cheers: Many Thanks
PostPosted: Wed Nov 30, 2011 1:42 pm
OAP
Items should be with you tomorrow or Friday latest. :thumbright:
PostPosted: Wed Nov 30, 2011 6:18 pm
:huray:
PostPosted: Thu Dec 01, 2011 8:48 pm
OAP
Just a quicky to say Thank You Myson for the excellent customer service as usual.
Bleed valves received with thanks. :thumbright:
PostPosted: Thu Dec 01, 2011 9:05 pm
...and a huge thanks to thescruff, I now have a nice hot rad. :-)
PostPosted: Tue Jan 03, 2012 11:09 pm
I had the same problem 1/2 inch brass available from Homebase and B&Q but threads to wide. British Gas came to complete bolier service and had 2 on his van Myson Air Bleed Shoulder Vents. I still need a further 5 of these so have emailed Myson still not sure what size they are.
PostPosted: Tue Jan 03, 2012 11:22 pm
OAP
They'll need a pic showing the valve and the end/top of the rad.
cookie's pic was perfect.
Users browsing this forum: No registered users and 6 guests
