-> Plumbing Forum |
| Author |
Message |
PeterVincent Junior Member
Posted: Wed Jul 16, 2008 2:30 pm Post subject: Blanking off T piece |
I have removed an existing shower and installed a new one. I now have no need for a feed from a T piece from cold outlet in the attic header tank.
I have tried to blank it off with a 0.5 inch blanking cap from a plumbers merchant but what I find is that I have run our of thread before I am happy with the tightness.
The fibre washer is present and to try and improve things I have put some PTFE (plumbers tape) around the thread, but it still looks as if I have run out of thread on the male.
I have left it over night with 2m head and there is no weeping.
I have tried to attached a picture of the T piece without sucess.
Should I leave the blanking cap alone now?
Thanks,
Peter
| Back to top |
thescruff Senior Member
Posted: Wed Jul 16, 2008 2:43 pm Post subject: |
A pic would be nice of the Tee and cap.
If you click on reply at the bottom there's a box where you can browse your computer for the pic, click on open add a few words and submit.
The pic should not be too large
_________________ Scruff |
| Back to top |
| Back to top |
Posted: Wed Jul 16, 2008 4:04 pm Post subject: |
The tape is doing nothing but if it don't leak leave it, I assume you have a blanking plug in the fitting
| Back to top |
Posted: Wed Jul 16, 2008 4:23 pm Post subject: Re blanking cap |
The brass fitting that you can see on top of the white tape is a cap, will take picture from another angle to show this later.
Thanks,
Peter
| Back to top |
Posted: Wed Jul 16, 2008 6:18 pm Post subject: |
RIght, I thought you had an Conex S61 blanking piece, a lump of brass that goes in the fitting and tightens up using the existing nut.
| Back to top |
Stoday Electricity economics consultant
Joined: 20 Jan 2006 Posts: 3227 Location: Sitting on the Bog
Posted: Thu Jul 17, 2008 1:01 am Post subject: |
| It's a Conex 63B and should have been used with a Conex 98 (a rubber washer).
| Back to top |
Posted: Thu Jul 17, 2008 4:31 am Post subject: |
Perfectly correct Stoday, except the 63b is complete with the washer and the 98 is a spare washer.
The 63b blanking piece is a better fitting in that it fits all brands an not just Conex
| Back to top |
Cannyfixit Senior Member
Posted: Thu Jul 17, 2008 11:40 pm Post subject: |
Excuse my ignorance but wouldnt it just been easier to replace the T with a straight whilst the water was off,you can rest easy then knowing it wont leak
_________________ Gary |
| Back to top |
Posted: Thu Jul 17, 2008 11:48 pm Post subject: |
| Cannyfixit wrote: |
Excuse my ignorance but wouldn't it just been easier to replace the T with a straight whilst the water was off,you can rest easy then knowing it wont leak  |
No more likely to leak than a reducing socket + the pipe would probably be too short so the OP would need a socket as well.
The Conex blanking disc would have been the easiest fitting to use, but not everyone knows what is available.
| Back to top |
| Back to top |
Posted: Wed Jul 23, 2008 10:15 am Post subject: |
That's a 63b Peter, they don't make an 372
I assume everything is dry in the camp
| Back to top |
Posted: Wed Jul 23, 2008 10:38 am Post subject: |
Scruff,
Is there an online catalogue that I can look at for the part numbers you are using. We are the imperial size fittings here, such as 14.7mm against 15mm.
I am looking at the Sanbra Fyffe one:
http://www.sanbrafyffe.ie/products.html
under Instantor Imperial Fittings top left corner, direct link http://www.sanbrafyffe.ie/pdfs/01%20imperial%20fittings.pdf
They call it a 372 and this is the only information that I can go on.
Elsewhere under Metric Instantor Compression Fittings metric fittings they call it a 472 link:
http://www.sanbrafyffe.ie/pdfs/04%20metric%20fittings.pdf
Many plumbers use the 15m on 14.7mm pipe and tighten the hell out of it to get the olive to give a water tight seal. I am not really happy with this.
Still dry!
Regards,
Peter
| Back to top |
Posted: Wed Jul 23, 2008 10:43 am Post subject: |
Hang on I'll have to change computers and I'// post the link for you.
What we do with imperial pipe is use the normal metric fitting and change the olive.
| Back to top |
Posted: Wed Jul 23, 2008 10:53 am Post subject: |
http://www.ibpconex.co.uk/
You should find the technical, product list and price from here, if not shout.
Look at the S 61 which would have been a better fitting for you.
| Back to top |
