It is currently Tue Jun 19, 2018 11:39 am
PostPosted: Wed Oct 25, 2017 3:09 pm
Has thanked: 63 times
Been thanked: 2 times
I have got a new house and the switch in the living room is behind the door as you walk in which really isn't very handy !
How the door opens has been changed around and makes more sense now.
I want to put a new switch in, that is accessible as you open the door and enter the room. The wire to the current switch are plastered in the wall so I intend to leave them there and run new 1.5mm.
Currently there is NOT T&E 1.5mm running to the light and switch as such. There is a single core(neutral) wire and a 2 core(Live,Earth) wire going to both and there is a junction box.
Hence my question is it standard now to wire at the switch rather than do it using a junction box or at a ceiling rose ?
PostPosted: Wed Oct 25, 2017 5:50 pm
Has thanked: 1443 times
Been thanked: 3686 times
Ummm not sure what you are asking... at the switch you have an earth, a permanent live and a switched live. No neutral at all.
A pic of the wiring at the light may help us advise better.
PostPosted: Wed Oct 25, 2017 6:46 pm
Yes sorry I was thinking of the light when I wrote it the switch is as you said " earth, a permanent live and a switched live".
I will add a pic
File comment: Picture of ceiling light
Power to the little people
PostPosted: Wed Oct 25, 2017 6:58 pm
Right. do you have access to the junction box and can you post a pic of the wiring there ??
PostPosted: Wed Oct 25, 2017 7:00 pm
I will work on getting pic of this..
PostPosted: Fri Oct 27, 2017 11:02 pm
This is the only one I have seen so far
PostPosted: Sat Oct 28, 2017 3:28 pm
Approved Electrician
Has thanked: 162 times
Been thanked: 562 times
Sorry to be the bearer of bad news but it looks like your lighting circuit has no earth.
This would mean that metal lightfittings are not allowed and also suggests - due to it's age - that all the electrics in the house need checking out.
PostPosted: Sat Oct 28, 2017 3:45 pm
concur with Only-me , unless it's just the switch that has no earth.
PostPosted: Sat Oct 28, 2017 9:06 pm
I believe this is going to the switch I am planning on moving. The lighting circuit does have an earth. I have also observed that all the lighting in the house is on the same circuit. This is what my question as about really. Since I plan to move a few light switches I was wondering if it might be better just to start a new circuit and put all the downstairs lights on it.
PostPosted: Sun Oct 29, 2017 8:44 am
erm, you have just posted a picture of what looks like an unearthed lighting circuit :scratch:
Care to post a couple of pictures of the wiring at a few of the the switches?
PostPosted: Sun Oct 29, 2017 6:33 pm
Or at other ceiling roses other ceiling lights ??
PostPosted: Wed Nov 01, 2017 1:49 am
More light switches pics added. Most of them are in partition walls but metal back boxes seem to have been used rather than plastic.
File comment: office 1G 2Way
File comment: Kitchen 1G 2way
File comment: Bedroom 1G 1Way
File comment: Living room 1G1Way
PostPosted: Wed Nov 01, 2017 5:06 pm
Read and understand this
http://www.ultimatehandyman.co.uk/how-t ... g-circuits
You'll then need to decide which method to use; you'll also need to find a ceiling rose or similar to take a permanent live/neutral /earth from.
Oh and those bare earths in your pics need sleeving.
For this message the author wine~o has received thanks - 2: ahll, multiman
PostPosted: Thu Nov 02, 2017 6:30 pm
Interesting photos.
You have quite a variety of wiring there, and certainly some of it is not earthed or not correctly earthed eg the kitchen.
The circuit needs testing properly. Bear in mind that just because there is an earth wire there does not mean it is earthed.
For this message the author OnlyMe has received gratitude : ahll
PostPosted: Sun Nov 05, 2017 2:07 pm
I have finally had time to do a more through investigation and the following are my findings. Please shout out if you think I have something wrong in my assessment ! I have added a few pics
Looking in the consumer unit :
Lighting Circuit
There are in fact 2 lighting circuits they are both on the same MBC
1 for the extension that was added which is earthed
the other I would suspect the original is not earthed and as you can see from the picture has a cable going from the MBC to a junction box connecting 3 wires..
Apart from the no earth issue on one I believe this should be on separate MCB's
Ring Mains
There are 2 again 1 for the extension and one for the original house.
Extension Ring
For the new ring that only issue I have is that instead of putting sleeving on both cpc's they have put them in the same one. Shouldn't they really be separate ?
Original Ring
There is another Connector to link the 2 neutrals to the neutral bar....is this the best way of doing it ?
Cooker Circuit
I noticed on this circuit that there was another connector block on the neutral which appears to be a lot less rating than the incoming. IS this an issue ?
File comment: Connector block on Neutral with reduced size cable to mcb
File comment: Old ring connector block used for neutral
File comment: Connector block used to connect 3 wires but no evidence of any Earth
2 Lighting Circuits 1 with connector for 3 wires .JPG [ 36.31 KiB | Viewed 386 times ]
