-> Carpentry/Joinery Forum |
| Author |
Message |
Gurkin Junior Member
Posted: Mon Jun 30, 2008 12:42 pm Post subject: Best way to fix a gate to external wall |
I'm in the motions of moving a 6ft wooden garden gate. At present the gate is fixed to a small wall (which is approx. 2ft wide) with some larch lap fencing on top. I want to remove the wall and move the gate into it's place. I was going to fix a post to the external house wall and then fix the gate to that. If that is OK what are the best fixings to use for attaching the post to the house? Obviously the gates gonna be hanging off of it so need to be pretty secure.
Thanks for any replies.
Gurkin |
| Back to top |
dirtydeeds Craftsman Carpenter
Posted: Mon Jun 30, 2008 6:08 pm Post subject: |
10x140 frame fixings
four should be more than enough |
| Back to top |
Posted: Mon Jun 30, 2008 8:58 pm Post subject: |
Thanks for your reply
I'm limited to B & Q, would either of these be suitable?
Option 1
Option 2
One other question, I was also going to attach the gate to a 4" x 2" post. Do you think this would be suitable?
Cheers |
| Back to top |
Gadget Jack Of All Trades
Joined: 18 Dec 2005 Posts: 3557 Location: Whitley Bay
Posted: Mon Jun 30, 2008 9:36 pm Post subject: |
Any of the 2 will suffice....and 4"x2" is fine! _________________ By eck! |
| Back to top |
Posted: Tue Jul 22, 2008 6:03 pm Post subject: |
Please help ASAP...
I finally got round to doing the gate, delayed due to cost of materials. Anyway, used 10mm x 135mm frame fixings for posts. The one thats attached to the house went on fine, after a bit of a bang with a hammer.
My problem is that on the one I'm trying to attach to a wall. What's happening is that the plug only goes in half way through the 4" x 2" so screwed in the screw as far as the plug and hoped to give it a bang again (i know this isn't the proper way to do this, but it appeared to work on the first one). Problem is the cheapie impact driver I saved for can't do the job and messed the screw up. Tried a second screw in another hole and the same thing happened. Now the screw heads are messed up completely from the driver, starting to bend from the banging and are sticking out about 40mm. I feel like a right dipstick!! What can I do to fix the problem tonight. Should I use an alternative instead. Maybe some sort of anchor fitting or something. I must get this done this evening as my garden is fully exposed...Please help!  |
| Back to top |
thescruff Senior Member
| Back to top |
Posted: Tue Jul 22, 2008 6:20 pm Post subject: |
Alternative get around would be to drill the holes and put the plugs in the wall first. _________________ Scruff |
| Back to top |
Posted: Tue Jul 22, 2008 6:24 pm Post subject: |
Hi Scruff. That's a great link as B & Q is the only thing available to me. What length bolt though. Should I buy the bolt separately?
Gurkin |
| Back to top |
Posted: Tue Jul 22, 2008 6:33 pm Post subject: |
| Also, How many of the rawlbolts do you think I would need. The height of the post is 2200mm. Am I right in thinking they are would be more secure. Should I drill new holes and start again. The existing holes are 150mm deep including the thickness of the post (2"). Sorry about all the questions. |
| Back to top |
Posted: Tue Jul 22, 2008 6:41 pm Post subject: |
I would use 4, two nearer the top say 400mm centers and the oth 2 space equally.
You could probably reuse the existing holes by drilling them out if you wanted too.
You will need to see what they have, regarding bolt length, but provided it will take 50mm fixing you should be ok, and yes it would be much stronger.
You need the M10 which from memory is an 12mm hole in the wall _________________ Scruff
| Back to top |
Posted: Tue Jul 22, 2008 6:43 pm Post subject: |
Thanks Scruff. You're a gentleman.  |
| Back to top |
fin Senior Member
Posted: Tue Jul 22, 2008 7:22 pm Post subject: |
if id have been doing that id have used spax screws. much better than frame fixings.
edit:
http://www.spax.com/gb/
we use the 80mm torx headed screws to fit pvc windows. neater job than frame anchors and they get a hell of a hold in brick work. and no need for plugs either. just drill a 6mm hole and drive it straight in.
a word of warning though. only use screws of sufficient length to go into the brick work maximum 2 inches or ya either snap the bit or knacker ya drill. |
| Back to top |
joiner_uk Senior Member
Posted: Tue Jul 22, 2008 9:40 pm Post subject: |
Wow thats a nice website
Is that why their screws are so expensive? _________________ Carpenter & Joiner Sheffield |
| Back to top |
fin Senior Member
Posted: Fri Jul 25, 2008 5:46 pm Post subject: |
there not so expensive really. can get em for a tenner ish a box iirc with discount nd all that. (thats for 80mm frame anchors) but the speed of the job, not having to use rawl plugs and having the torx type head so the driver bit rarely slips is great. plus they get a hell of a hold in brick work.
i fit a lot of pvc windows and doors. i always use those over anything else. perfect every time whereas with other types of frame fixings its not so good |
| Back to top |
gentleman jim Junior Member
Posted: Mon Aug 25, 2008 8:29 am Post subject: |
Hi read with interest all the various solutions, when ive got to fix posts to walls I use masonary bolts, all you need to do is drill the hole and get your socket wrench onto the bolt and drive it home .... has worked every time for me ....... _________________ live for the minute |
| Back to top |
