It is currently Tue Jul 17, 2018 8:54 am
PostPosted: Thu Oct 19, 2017 9:49 pm
Has thanked: 12 times
Been thanked: 3 times
I need to drill few 30mm holes about 7mm distance from to each other in thin plywood.
I don't have access to a drill press.
How would you keep the drill straight and prevent it from moving?
How would you do a clean cut from both sides?
Are there any good drill guides for such task?
PostPosted: Thu Oct 19, 2017 10:17 pm
Jack Of All Trades
Has thanked: 205 times
Been thanked: 276 times
30mm hole saw is the best way. https://www.orbitalfasteners.co.uk/en/p ... 2YQAvD_BwE
By eck! ©
PostPosted: Thu Oct 19, 2017 10:32 pm
Has thanked: 397 times
Been thanked: 1404 times
C1REX wrote:
7mm remaining in between 30mm holes (in the 3mm ply which you proposed using in your other topic) is going to leave it very weak, (imo).
PostPosted: Thu Oct 19, 2017 10:57 pm
ayjay wrote:
C1REX wrote:
It's super weak but there will be another plywood or polycarbonate.
Also when I put buttons in the drilled holes then it becomes as strong (or almost as strong) as before drilling.
I've tested it on a thin MDF. When I drilled holes even my baby son could break it but when I put buttons in it then my children couldn't break it.
Does anybody know if something like this works?Image
PostPosted: Thu Oct 19, 2017 11:29 pm
Has thanked: 673 times
Been thanked: 1934 times
aim for 6mm[5.5mm ] thick material
pile about 5 or 6 on top off each other and cut onto a scrap bit off material with the top sheet up side down
lube with ptfe spray lubricant
PostPosted: Fri Oct 20, 2017 8:23 am
Has thanked: 82 times
Been thanked: 216 times
A drill press would be good , keeps everything nice and straight and can be left set up. Drilling through several layers would both speed things up and reduce the possibility of spelching through.
However , as you don't have access a drill press I'd advise the same approach as I answered before , a router and jig. Holes could be roughly drilled to remove most of the waste , a bundle of pieces place in the jig and the router run round to clean up the holes. A jig in this case is really little more than a sheet of ply or similar with a large circular hole against which the base of the router is run.
