Ultimate Handyman Home
Best way to deal with uneven height walls after tiling
Goto page 1, 2  Next
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Tiling Forum
Hoovie
Devon DIYer
PostPosted: Sun Sep 16, 2007 9:07 pm    Post subject: Best way to deal with uneven height walls after tiling Add User to Ignore List Reply with quote
Just tiled my bathroom (up to ceiling) and carefully worked out where to start and finish to eliminate slivers of tiles, etc.
What I didn't realise until too late was the ceiling sloped Bang Head - so now I have a nice tight line on one wall to the ceiling and a gap of around 25mm on the opposite wall to the ceiling as I used a spirt level to fix the supporting batten - and on the walls that connect these two, the gap from top of tile to ceiling obviously starts to increase - 3mm to 25 mm over around 1.4 Metre length.
Any suggestions about how to deal with this?
I have thought about listellos about 25-30mm deep that would sit on top like a feature, following the line of the ceiling but have not seen any I like - and the price of some of these seem insane - like £5 for a 75mm listello!
Tiles are basic 200x200 slightly bumpy plain white ceramic tiles with a 2mm tile space.
BTW - any suggestions that involve removing tiles and redoing it will not be welcomed - that is NOT an option as I do not enjoy tiling and could not face repeating any work Crying
Thanks,
Hoovie.
Back to top
Jaeger_S2k
PostPosted: Sun Sep 16, 2007 10:46 pm    Post subject: Add User to Ignore List Reply with quote
I can't think of a quick fix that won't look similar if not worse than the tile (if you finished the cut).
At those prices for listello I'd be tempted to go to your local wood merchant and have him rip some 1" x 1 1/2" from 25mm to zero at the length required and board out the ceiling. with 9mm plasterboard, and finish as drywall.
Unless someone has a better idea?
Jaeger.
FSBF
Back to top
tim'll fix it
PostPosted: Sun Sep 16, 2007 11:34 pm    Post subject: Add User to Ignore List Reply with quote
coving
Decking
Back to top
bathstyle
BATHROOM DESIGN AND INSTALLATION
PostPosted: Sun Sep 16, 2007 11:40 pm    Post subject: Add User to Ignore List Reply with quote
Double tack the ceiling
Back to top
Hoovie
Devon DIYer
PostPosted: Mon Sep 17, 2007 7:57 am    Post subject: Add User to Ignore List Reply with quote
What does this mean? (sorry, not heard this term before)
Back to top
Jaeger_S2k
PostPosted: Mon Sep 17, 2007 8:00 am    Post subject: Add User to Ignore List Reply with quote
What I said, but a lazy version.
Jaeger.
FSBF
Back to top
Hoovie
Devon DIYer
PostPosted: Mon Sep 17, 2007 8:07 am    Post subject: Add User to Ignore List Reply with quote
Cheers!
Right .... so conclusions are basically get the ceiling level!!
I am gonna get someone in to sort out my plaster and lath artexed landing ceiling and I think I will get him to do the bathroom at the same time (got a patch of bare Plasterboard on ceiling where I took out the airing cupboard to get done anyway)
Is a 25mm gap too big to be "skimmed" (I know it is more then a skim, but you know what I mean (probably!!))?
Back to top
panlid
PostPosted: Mon Sep 17, 2007 8:08 am    Post subject: Add User to Ignore List Reply with quote
double tack, thats a new one on me!
i like these technical terms, they make it sound like we are specialists Laughing
Back to top
Hoovie
Devon DIYer
PostPosted: Mon Sep 17, 2007 8:11 am    Post subject: Add User to Ignore List Reply with quote
I think I could have a go and try to persuade the wife to look at cladding the ceiling like UHM did in a bathroom - that looked pretty good.
Back to top
panlid
PostPosted: Mon Sep 17, 2007 8:18 am    Post subject: Add User to Ignore List Reply with quote
if you have a planer just put an inch strip of wood at the high end, a couple more strips getting thinner (planer)
then just put some some cladding up. for cladding you only need rails every couple of feet.
Back to top
Hoovie
Devon DIYer
PostPosted: Mon Sep 17, 2007 8:27 am    Post subject: Add User to Ignore List Reply with quote
Thanks, Panlid - This option is sounding better and better as it deals with a few things in the one solution - and I do have a planer
(I also know to keep my fingers away from rotating sharp bits (sorry, A. Wink ) - I have been using a Junior hacksaw instead on the fingers Crying )
Cheers,
Hoovie
Back to top
Jaeger_S2k
YES.
If it fell on you, highly likely, it'll kill you!
Jaeger.
FSBF
Back to top
Jaeger_S2k
PostPosted: Mon Sep 17, 2007 10:08 am    Post subject: Add User to Ignore List Reply with quote
Cheers,
Hoovie
That's what I said way back, you could have had it done by now.
Why you no rissen? Wink
Jaeger.
FSBF
Back to top
Hoovie
Devon DIYer
PostPosted: Mon Sep 17, 2007 10:21 am    Post subject: Add User to Ignore List Reply with quote
Cheers,
Hoovie
Ahhh - you talked about Drywall (which will mean the evil of Plastering)
I will give anything a go in the house EXCEPT I try and avoid things that will be on show, such as tiling (you now know why!) and plastering (the paint is too thin to hide a non-smooth surface)
depending on direction of cladding (either following 1.4M wall or following 3.6M wall), I will be able to use battens of various thicknesses to level, or battens with varying thickness to level - either one will suit me as I have a head with various degrees of varying thickness Laughing
Back to top
Hoovie
Devon DIYer
PostPosted: Sun Oct 28, 2007 6:01 pm    Post subject: Add User to Ignore List Reply with quote
Just thought I would post an update on this as finally completed this job Thumbright
In the end I went for Painted T&G cladding with a Scotia Beading to hide the expansion gap.
Ceiling battened out ready for Cladding, with downlighter holes cut through old plaster in readiness for next stage (thanks to all for the advice and confirmation about shimming, batten sizes, etc Thumbright )
Cladding up (pre-painted mostly in strips and then final coat once assembled)
Ceiling Complete - at last!
Now I can start working down to the floor!
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Tiling Forum All times are GMT
Goto page 1, 2  Next
Page 1 of 2
