It is currently Fri Sep 21, 2018 7:29 pm
PostPosted: Fri Jul 21, 2017 8:16 pm
Has thanked: 46 times
Been thanked: 6 times
I'm almost ready to start fitting my new engineered wood flooring. It's 14mm thick (top layer oak 2mm and two layers pine(?) 12mm), 2.2m long and 18cm wide.
I was going to buy this: http://www.argos.co.uk/product/7153390 but it turns out it's a four day pre-order and I need it tomorrow... I found a tool shop that has it on their website but it's a good hour drive and I'm not sure they have it in stock. But they open at 7:30 so could call and check, don't mind the drive if that tool is good for the purpose. I'll probably have to cut four or five of those floorboards length-wise.
So basically I want to know if that tool is good for this job (providing they have it in stock) and what are the alternative in case they don't have it. I don't mind spending up to about £100.
What do you guys think I should do?
PostPosted: Fri Jul 21, 2017 8:24 pm
Has thanked: 52 times
Been thanked: 545 times
A crosscut saw and a jigsaw will do the trick
A sliding square is useful
Most cuts are hidden anyway tbh
For this message the author Bob225 has received gratitude : tadaska
PostPosted: Fri Jul 21, 2017 8:58 pm
Has thanked: 84 times
Been thanked: 224 times
http://www.screwfix.com/p/irwin-jack-un ... UQodxEwAjg
I'm a joiner and frankly 99% of cuts can be done with one , it's only 14mm thick so ripping isn't that much of a problem. As said most cuts are covered anyway and cutting face side up won't cause any spelching . Utting by hand is generally a little slower so cutting by hand is not only good experience there's less chance of making a mistake than there would be with power tools.
For this message the author Grendel has received gratitude : tadaska
PostPosted: Fri Jul 21, 2017 9:29 pm
I have a manual saw but I really don't fancy doing so much cutting by hand :cb
When cutting by hand or with a jigsaw, what is the best way to support the floorboard?
For this message the author tadaska has received gratitude : multiman
PostPosted: Fri Jul 21, 2017 11:08 pm
Has thanked: 696 times
Been thanked: 28 times
A piece of wood would suffice
For this message the author multiman has received gratitude : tadaska
PostPosted: Fri Jul 21, 2017 11:45 pm
Has thanked: 691 times
Been thanked: 1952 times
ok my thoughts
that saw is a waste off money because
its difficult to use
no flowing movement in use
has no other use
will not be a generally useful saw
a jigsaw or handsaw will do the same job
a powered mitre saw [like evolution rage] will have greater capacity and do perhaps 50 times the task for similar or slightly more outlay
edit
ok just realized it can do rip cuts buuuuttt
90% off rip cuts on laminate are not parallel so comments above still apply
thinking you can rip a parallel length will make installation easy it wont as the walls will not be parallel so will cause no end off problems :cb
For this message the author big-all has received thanks - 2: multiman, tadaska
PostPosted: Sat Jul 22, 2017 10:25 am
rip cut - use a straight bit of timber and clamp it down to the board and use it as a guide for the jigsaw, edges are covered by the skirting or scotia and allows for a bit of a iffy cut/expansion gap
For this message the author Bob225 has received thanks - 2: multiman, tadaska
PostPosted: Sat Jul 22, 2017 12:22 pm
Never felt or needed anything more complicated than one of these,
http://s3.amazonaws.com/bvsystem_tmp/pa ... 1314124955
Mine doesn't have the central timber stretcher but it does have a piece fixed to two legs on the same side which turns it into a useful hop up. I cover the top with sacrificial ply which gets changed ever so often.
For this message the author Grendel has received thanks - 2: multiman, tadaska
