Ultimate Handyman Home
Bench grinder
Post new topic   Reply to topic    www.ultimatehandyman.co.uk Forum Index -> BUY
Cannyfixit
PostPosted: Tue Jun 10, 2008 7:58 pm    Post subject: Bench grinder Add User to Ignore List Reply with quote
can anyone reccomend a decent bench grinder i do a bit of alluminium polishing in my spare time,i have used the budget grinders but they grind to a halt (excuse the pun) when i apply pressure
a friend says i need a minimum of a 550 watt motor theres one on Ebay at the moment made by Axminster,looks right for the job but i thought i'd check with the pro's before splashing out with the hard earned
cheers folks
http://cgi.ebay.co.uk/Axminster-AW8G2-Heavy-Duty-Bench-Grinder_W0QQitemZ370059135253QQihZ024QQcategoryZ121893QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Gary
Back to top
EJJ150847
PostPosted: Wed Jun 11, 2008 7:26 am    Post subject: Add User to Ignore List Reply with quote
Most grinding wheels don't like aluminium as it is a soft metal and clogs them, make sure you buy a wheel specific for ali. This could be the cause of your problem, overloading the grinder.
John
Mebyon Kernow
Back to top
Cannyfixit
PostPosted: Wed Jun 11, 2008 9:17 pm    Post subject: Add User to Ignore List Reply with quote
Sorry Johni should have said,I use the polishing mops designed for use on a bench grinder,the stone wheels are removed and replaced with spindles,it the motor that's under powered when using the stitched sisal mops for course cutting
thanks for your reply Thumbright
Gary
Back to top
Display posts from previous:
Post new topic   Reply to topic    www.ultimatehandyman.co.uk Forum Index -> BUY All times are GMT
Page 1 of 1
