It is currently Thu Apr 19, 2018 12:48 pm
Visit Thermo worx
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 11 posts ]
 Post subject: belmont radiator valve
PostPosted: Fri Nov 19, 2010 12:08 pm
Can someone please explain in simple terms (as i am a simple man) how to repair a leaking belmont radiator valve. the leak is coming through the top of the valve when it's open. is it possible to replace the o rings ? how ? how much water will leak out when i do it? do i need to drain the system ? thanks
PostPosted: Fri Nov 19, 2010 12:19 pm
Has thanked: 36 times
Been thanked: 207 times
Take off the shroud and try tightening the nut around the spindle a little.
John
PostPosted: Fri Nov 19, 2010 3:30 pm
Has thanked: 422 times
Been thanked: 3903 times
:withstupid:
If that doesn't work run the nut off and put 5-6 turns of ptfe tape in the gap and do the nut back up.
If you change the O rings it's a drain down.
PostPosted: Fri Nov 19, 2010 7:31 pm
Has thanked: 1 times
If you can hold your nerve, you dont have to drain down with Belmont valves,they have an in built cut off that allows you to remove the spindle from the valve to change O rings....If you can still get them. Most on here probably never come across them.
PostPosted: Fri Nov 19, 2010 8:01 pm
That's what i'd read elsewhere but as soon as I begin to loosen the nut it leaks straight away. Is that normal ? does the spring mechanism activate when the nut is removed ?
PostPosted: Fri Nov 19, 2010 8:03 pm
Has thanked: 307 times
Been thanked: 942 times
Ouch! Wait for it :boxing:
:lol:
That's true, never tried it though, always found them very reliable
PostPosted: Sat Nov 20, 2010 9:19 am
:lol:
What are we waiting for? :dunno:
PostPosted: Mon Nov 22, 2010 10:44 am
Does "holding my nevre" mean that I have to losen the nut and have faith that the water will stop once it is removed ?
As you may have guessed I am a novice and am concerned that removing the nut is going to result in lots of water !!!
PostPosted: Mon Nov 22, 2010 6:02 pm
If your any way scared of tackling the job,then I suggest you save up and replace with decent energy TRVs and Lockshields.
PostPosted: Mon Nov 22, 2010 10:06 pm
You wont get much better than Belmont valves. :scratch:
