It is currently Tue May 22, 2012 9:26 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 11 posts ]
PostPosted: Wed Jan 11, 2012 7:33 pm
Hi All
I am a total novice and newcomer so please don't laugh.
I have a Beko WM6123W washing mashine. It has packed up and i have been told i need to replace the brushes.
Obviously to do this i need to remove the motor. I have manged to remove the front 2 screws holding the motor in place but It appears that there are 2 more screws at the back which seem impossible to reach ?
Could anyone please tell me that i am right and it is impossible to move the flippin motor ?
Thanks in advance
James
PostPosted: Wed Jan 11, 2012 7:48 pm
UHM Super Moderator
Has thanked: 1 times
Been thanked: 63 times
James,
I moved your thread to the DIY Forum as you will have a better chance of getting a satisfactory reply.
mod5
PostPosted: Wed Jan 11, 2012 7:54 pm
UHM Super Moderator
Pair of brushes available here:
http://www.4beko.co.uk/washing-machine/ ... ref=620362
You could ring the help line number and ask them how to get at the back bolts on the motor, if no one comes up with a solution on here.
mod5
PostPosted: Wed Jan 11, 2012 7:56 pm
mod5
Thank you
PostPosted: Wed Jan 11, 2012 8:58 pm
Has thanked: 6 times
Been thanked: 108 times
What tools are you using, probably just a case of needing a smaller ratchet, or different spanner....?
What is in the way?
I'm not familiar with the machine, but shouldn't be too challenging.
PostPosted: Wed Jan 11, 2012 10:00 pm
Has thanked: 134 times
Been thanked: 468 times
may or may not be able to remove brushes without removing the motor dependent on design :dunno:
PostPosted: Thu Jan 12, 2012 3:13 pm
What is in the way?
Hi
I am using a plain old alan key (this was successful in removing the front screws). The screws at the back are in an impossible position to reach.
PostPosted: Fri Jan 13, 2012 8:21 pm
What's in the way? might need to move something to get to them? Or turn it on its side.....?
PostPosted: Sun Jan 15, 2012 4:58 pm
I managed to change the brushes ok in the end.
It hasn't made the slightest bit of difference. I am at a total loss as to what the problem is.
:sad:
PostPosted: Sun Jan 15, 2012 10:03 pm
Oh dear.
Whats the symptoms, prior to it dying? What does/doesn't it do at the moment....?
PostPosted: Sun Jan 15, 2012 10:30 pm
Has thanked: 33 times
Been thanked: 42 times
I found that the high speed motors can just die, probably shorted turns, which don't show up with a simple continuity test.
