Ultimate Handyman Home
Beeline paste
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Painting & Decorating Forum
Sreed101
Junior Member
PostPosted: Tue Jan 29, 2008 10:02 pm    Post subject: Beeline paste Add User to Ignore List Reply with quote
Have just taken a wallpapering job on that involves using ready mixed paste.I have used it before and gave as up as a bad thing and used a strong mix of solvite.
Can anyone tell me the tricks to using it as last time i had no movement once it touched the wall and if im linning first do i use it for that aswell.
Please help Crying
Back to top
Welsh Decorator
PostPosted: Tue Jan 29, 2008 11:51 pm    Post subject: Add User to Ignore List Reply with quote
welcome Sreed, how are you useing it? is it straight from the tub? or do you thin it any? scratch
Ready mixed will stand some thining, albeit not a great deal, it's desigend to be high solids, low water.
If after a little thining it still is grabing, try either, sizeing the lining, or Zinsser Sheldz. Thumbright
If this don't work..........I give up! Laughing
I'm not a roman mum, I'm a kike, a yid, a heebie, a hook-nose, I'm kosher mum, I'm a Red Sea pedestrian, and proud of it!
Back to top
View user's profile Send private message Yahoo Messenger
Sreed101
Junior Member
PostPosted: Wed Jan 30, 2008 8:17 am    Post subject: Add User to Ignore List Reply with quote
Thanks for your reply
I am advised by paper manufacture to use it straight from the tub.
What is the best way to apply it,ie brush roller or do i need to do it with a pasting machine. Bang Head
Back to top
Telmay
PostPosted: Wed Jan 30, 2008 8:48 am    Post subject: Add User to Ignore List Reply with quote
Brush or roller - dont put in a machine its far too thick to work in one
Back to top
Welsh Decorator
PostPosted: Wed Jan 30, 2008 11:41 am    Post subject: Add User to Ignore List Reply with quote
Tel's right, without thining, it will not go through a machine. Crying
Sounds like you are useing Laura Ashley paper, but a short pile roller will do it, I would thin the stuff in line with the manfr's recomend's just to make life that bit easyer and save the potential of paste ridges under the paper on drying.
I seem to recall that Beeline used to have two marks on there tub's for different dilution rates? I think that one was for a spredder and the other for brush, but I think that the maximum amout you could thin by was around 6pts, without any loss of addhesion.
It might be, that you might have to do a little experamentation with it, to find the best for that job.
Be interesting to know how you get on, what tweeks you make to it also just what paper are you are lumberd with. Thumbright
Back to top
tim'll fix it
PostPosted: Wed Jan 30, 2008 11:59 am    Post subject: Add User to Ignore List Reply with quote
i used some harlequin ready mixed paste once, it was recommended for the paper, horrible stuff, dried to quick and caused alsorts of bubbling problems, in the end I went back to powdered solvite and the job was much easier
Decking
Back to top
fordy
Member
PostPosted: Wed Jan 30, 2008 4:22 pm    Post subject: Add User to Ignore List Reply with quote
Get the solvite ready mixed use for finish paper and never have a problem!! Add water to what u feel comfortable with!!
Used beeline before and tried to mix it with water and it went all clumpy on me had to lob the lot didnt get on with it,lol
Back to top
feva
PostPosted: Wed Jan 30, 2008 9:08 pm    Post subject: Add User to Ignore List Reply with quote
how do you guys use a roller to paste with? every time ive tried its gone evey where so i had to give up and do it with a 7'' brush
such is life!
Back to top
Sreed101
Junior Member
PostPosted: Wed Jan 30, 2008 10:10 pm    Post subject: Add User to Ignore List Reply with quote
Thanks again for your help
Not sure what paper they are using (its good quality not L A) as its a job with a contractor and a big one at that.
I have to line before so will i have to use readymix for that aswell. The walls are about 12-14ft,will adding water or pasting the wall aswell as the paper give me more time to match.
Thanks again
Back to top
Welsh Decorator
PostPosted: Fri Feb 01, 2008 2:08 am    Post subject: Add User to Ignore List Reply with quote
Adding some water will help, but if it wet time that you really need, try Zinsser Sheildz.
Back to top
brushmate
PostPosted: Sat Feb 02, 2008 7:59 pm    Post subject: Add User to Ignore List Reply with quote
SREED 101 you will be ok to use ordinary paste for the lining paper
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Painting & Decorating Forum All times are GMT
Page 1 of 1
