Ultimate Handyman Home
beech timber, what finish to use?
Goto page 1, 2  Next
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Carpentry/Joinery Forum
dadtojj1
Junior Member
PostPosted: Sat Apr 21, 2007 8:28 pm    Post subject: beech timber, what finish to use? Add User to Ignore List Reply with quote
Hi Guys,
i have just finished building a coffe table from beech, but have never worked with it before so am unsure what finish to use, i want to leave natural, but need it well protected, have any of yu any suggestions ?
thanks
steve
Back to top
Hitch
PostPosted: Sat Apr 21, 2007 8:32 pm    Post subject: Add User to Ignore List Reply with quote
Id would consider an oil finish for that.
Something like Liberon finishing oil.
An oil finish is often used on worktops, it will give you a satin finish.
Back to top
Dirk Diggler
PostPosted: Sat Apr 21, 2007 8:33 pm    Post subject: Add User to Ignore List Reply with quote
what about some nice teak oil
Decking | Plumbers
Back to top
panlid
PostPosted: Sat Apr 21, 2007 8:40 pm    Post subject: Add User to Ignore List Reply with quote
danish oil.
or a nice coat of white gloss Wink Laughing
Back to top
owen
PostPosted: Sat Apr 21, 2007 9:29 pm    Post subject: Add User to Ignore List Reply with quote
yep a nice oil finish looks good on beech
Back to top
carhartt kid
PostPosted: Sun Apr 22, 2007 1:33 am    Post subject: Add User to Ignore List Reply with quote
Briwax clear or Colron finishing wax...
http://www.carhartt.com/
Back to top
tim'll fix it
PostPosted: Sun Apr 22, 2007 6:53 am    Post subject: Add User to Ignore List Reply with quote
i like a waxed finish but danish oil will protect it from water damage where as wax wont
Decking
Back to top
Hitch
PostPosted: Sun Apr 22, 2007 8:56 am    Post subject: Add User to Ignore List Reply with quote
I have some of that Colron wax, realy couldn't get on with it, it just doesnt seem to go into the wood at all. Confused
Back to top
panlid
PostPosted: Sun Apr 22, 2007 9:00 am    Post subject: Add User to Ignore List Reply with quote
must admit, like tim i like a wax finish. the briwax clear is really nice to use. i hate that liquid wax from colron.
if the coffee table is to be looked after i would err towards wax. if using danish oil just put on very thin coats with wire wool in between.
Back to top
tim'll fix it
PostPosted: Mon Apr 23, 2007 7:30 am    Post subject: Add User to Ignore List Reply with quote
briwax gives the best finish imo
colron stuff just doesnt cut it
Decking
Back to top
petengade
Member
PostPosted: Mon Apr 23, 2007 8:44 pm    Post subject: Add User to Ignore List Reply with quote
If it was for me I would give two coats of sanding sealer than apply wax then put a sheen on it rubbing with a soft cloth. do a Google for sanding sealer.
Back to top
PostPosted: Tue Apr 24, 2007 7:22 am    Post subject: Add User to Ignore List Reply with quote
Well this might go against the mainstream of suggestions but I would use matt acrylic varnish. Dulux do a very hard finish water based varnish that will seal the wood well but not discolour it. Wax will be useless for a table top as it will show rings from hot cups etc.
I do three coats with good sanding and clean down in between. A good natural look finish for beech that is resilient to normal use.
Back to top
tim'll fix it
PostPosted: Tue Apr 24, 2007 7:40 am    Post subject: Add User to Ignore List Reply with quote
varnish will chip though imo
Decking
Back to top
PostPosted: Tue Apr 24, 2007 1:07 pm    Post subject: Add User to Ignore List Reply with quote
Well I have never had any chip up Tim, but it is all down to use. If you put your feet up on the table and do not remove your spurs then yes, it would chip Laughing . For most uses though such as cups, glasses etc it will take the wear well. You never see table tops on furniture in shops that is not laquered.
Back to top
tim'll fix it
PostPosted: Tue Apr 24, 2007 4:24 pm    Post subject: Add User to Ignore List Reply with quote
are you mrs tim Laughing
Decking
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Carpentry/Joinery Forum All times are GMT
Goto page 1, 2  Next
Page 1 of 2
