-> Carpentry/Joinery Forum |
| Author |
Message |
petengade Member
Posted: Tue Apr 24, 2007 7:56 pm Post subject: |
| DWD, invest in some table mats, problem solved. |
| Back to top |
dewaltdisney Senior Member
Posted: Wed Apr 25, 2007 8:33 am Post subject: |
But they are so pass'e P
DWD |
| Back to top |
Scrit Pro Cabinetmaker
Joined: 27 Dec 2005 Posts: 394 Location: The Sunny Pennines
Posted: Wed May 02, 2007 12:56 pm Post subject: |
| dewaltdisney wrote: |
| Well this might go against the mainstream of suggestions but I would use matt acrylic varnish. Dulux do a very hard finish water based varnish that will seal the wood well but not discolour it. Wax will be useless for a table top as it will show rings from hot cups etc. |
I'm with DWD here. Wax is no good for a table where hot cups will stand and oil will darken the timber too much. The Dulux stuff is called Diamond Glaze although Rustin's and Ronseal both do a water-based acrylic flooring lacquer as well which work in a similar way
Scrit _________________ Measure twice, cut once - except fingers! |
| Back to top |
