Ultimate Handyman Home
Bedroom double glaze window not airtight
Post new topic   Reply to topic   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Building Forum
siraz
Member
PostPosted: Mon Sep 29, 2008 5:11 pm    Post subject: Bedroom double glaze window not airtight Add User to Ignore List Reply with quote
Hi All,
I have this noise and bit of draft coming from the front bedroom window. I have been advised to change the hinge and i did but there is no difference.
Am i using the correct type hinge, as the one on the window is the orignal, which i need to replace the one which is on the blue carpet. These hinges are new, as they just came off from Velux windows, as they were changed due it needed to have Heavy duty hinge.
I only have the gap at the centre on the top of the opener, as the 2 sides and bottom edged is tight against the frame. The gap start from the 1/3rd of the edge on either side of the top opener
So please advise any suggestion.
see belwo website for pictures
http://s268.photobucket.com/albums/jj19/siraz_bucket/
http://s268.photobucket.com/albums/jj19/siraz_bucket/?action=view&current=S8301148-1.jpg
Regards
Siraz
Back to top
lockie
PostPosted: Mon Sep 29, 2008 9:58 pm    Post subject: Add User to Ignore List Reply with quote
On top of the window are two lugs that locate into a keep on the frame,are these lugs actually going into the keeps or outside the keeps.If they are not going into their keeps that would cause the gap at the top.
Your photo S8301162.jpg show the grey coloured lug on the top of the window and black keep above it on the frame.
london based locksmiths
Back to top
siraz
Member
PostPosted: Wed Oct 01, 2008 10:53 am    Post subject: Add User to Ignore List Reply with quote
Hi Lockie,
It does goes in the lug and i still have the gap.some trades person are saying it may the hinges or the locking lugs on the frame and window.
Back to top
PostPosted: Wed Oct 01, 2008 12:18 pm    Post subject: Add User to Ignore List Reply with quote
hold a strait edge along the face of the top of the frame/window where the gap/noise is and see if there is any bumps or hollows
often the frame can be pulled out of line by a squint fixing
somtimes you can get slighty larger rubber gasgets to fill the gap
all these measures assume the opening is square withan even spacing all around
Back to top
siraz
Member
PostPosted: Wed Oct 01, 2008 3:34 pm    Post subject: Add User to Ignore List Reply with quote
Hi Big All,
What is squint fix ?
There is no screws being used, as it has been fixed by foam fixing.
Back to top
lockie
PostPosted: Wed Oct 01, 2008 10:14 pm    Post subject: Add User to Ignore List Reply with quote
Can you confirm the frame is straight/true and the window is straight/true in the open position ? Btw im also a tradesman lol
Back to top
PostPosted: Wed Oct 01, 2008 11:47 pm    Post subject: Add User to Ignore List Reply with quote
siraz wrote:
Hi Big All,
if the central fixing is 6mm out of line for example it can pull the frame out of line causing a gap the sealing rubber gasget cant cover
using foam without a mecanical fixing[bolt /screw/for example]is not a good idea as the foam is only expected to last around 10 years!!!!
Back to top
siraz
Member
PostPosted: Mon Oct 06, 2008 5:15 pm    Post subject: Add User to Ignore List Reply with quote
Hi Big All,
You right i remeber they never used any mechanical screws/ bolt, as they only used foam to fix the windows.
I need to check if the frame is striaght or not with the level for vertical and Horizontal with window closed and open.
Back to top
Display posts from previous:
Post new topic   Reply to topic    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Building Forum All times are GMT
Page 1 of 1
