Ultimate Handyman Home
bedroom ceiling
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plastering Forum
vespabill
Junior Member
PostPosted: Wed Aug 20, 2008 8:48 pm    Post subject: bedroom ceiling Add User to Ignore List Reply with quote
bedroom ceiling has a coarse painted grit like appearance like a flexible paint to cover up cracks. it is all sound and stuck well to ceiling.is it possible to skim straight over the top. thanks
Back to top
leebwk
PostPosted: Thu Aug 21, 2008 2:33 pm    Post subject: Add User to Ignore List Reply with quote
As long as it is not flaking or coming away then i would PVA it and skim it,
firstly try and scrape some off if it comes off easily then this is a big no no if it is stuck on soundly then you should be ok
What was the best thing before sliced bread?
Back to top
vespabill
Junior Member
PostPosted: Thu Aug 21, 2008 4:46 pm    Post subject: Add User to Ignore List Reply with quote
thanks will skim over as it is really sound.
Back to top
LUFC
PostPosted: Tue Aug 26, 2008 7:23 pm    Post subject: Add User to Ignore List Reply with quote
pva it it, pva usually makes it bubble if its going to come away,
give it a scrape and then if its all good then skim it
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plastering Forum All times are GMT
Page 1 of 1
