Ultimate Handyman Home
Battery v Corded
Post new topic   Reply to topic   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Tool Talk
Hoovie
Devon DIYer
PostPosted: Mon Jul 07, 2008 4:30 pm    Post subject: Battery v Corded Add User to Ignore List Reply with quote
Tools in General
I have found Cordless Drills to be generally brilliant and do just about all you want of them.
When it comes to Saws, it is another matter.
My Ryobi One+ Jigsaw will do maybe 5-10 metres worth before it starts to stutter on anything at all demanding.
My Ryobi One+ Circular saw does not last more then a couple of metres before it stops on any pressure. I am not sure about how good the blade is - bought the saw 2nd hand so don't know what kind of life it had before me.
tried both will fully charged batteries and they kill the batts so quick, need 3 fully charged ones for the average 30 mins or so of project cutting time
Are Cordless Saws generally ok scratch
Don't forget to vote in the "Member Location" poll in the Lounge Thumbright
Knowledge is Knowing a Tomato is a Fruit, Wisdom is Not putting It in a Fruit Salad
Back to top
Hitch
PostPosted: Mon Jul 07, 2008 5:07 pm    Post subject: Add User to Ignore List Reply with quote
I had a ryobi one, it would happily cut 20mm oak, but only a couple of metres per charge. (1.7ah nicads)
I miss it for the odd chop here and there, but i prefer corded for most tools.
Back to top
chippymike
PostPosted: Mon Jul 07, 2008 7:33 pm    Post subject: Add User to Ignore List Reply with quote
The trim saws are only meant for 6mm ply for soffits and 12mm etc, your best off with a cordded skill saw for long runs.
Back to top
View user's profile Send private message MSN Messenger
Hoovie
Devon DIYer
PostPosted: Mon Jul 07, 2008 7:47 pm    Post subject: Add User to Ignore List Reply with quote
I'm beginning to think that Laughing
I have got a mains Bosch Circular Saw, but Cordless is so convenient I keep trying it - but doesn't seem man enough for the job Sad
Back to top
PostPosted: Mon Jul 07, 2008 9:27 pm    Post subject: Add User to Ignore List Reply with quote
yes the circular saw will run the batterties but you should get 20 or 30ft in 12mm ply or mdf no probs per battery
blunt blade wont help work must be fully suported to stop pinching on the blade
i quite happily cut 18mm ply or mdf with the ryobi but if i have more than a few cuts i will use the 24v bosch or the dewalt dw62 mains
i use the ryobi 94.99999% of the time the bosch 5% off the time and the dewalt was it before or after the milenium i last used it scratch !!!!!!!!!!
Back to top
chippymike
PostPosted: Tue Jul 08, 2008 8:52 pm    Post subject: Add User to Ignore List Reply with quote
big-all if its been that long for the dewalt, you best check it still works Laughing
big-all have you tryed the ryobi lith-ion batts yet?
Back to top
Paslode_itw
Junior Member
PostPosted: Wed Jul 09, 2008 5:56 pm    Post subject: Add User to Ignore List Reply with quote
hows the bosch big all?
Back to top
benshaw
Junior Member
PostPosted: Fri Aug 15, 2008 3:50 am    Post subject: Add User to Ignore List Reply with quote
Although I can't put a figure on it, the new Ryobi lithium batteries have transformed my circular saw. They cost as much as the tools but you will not regret buying them.
Back to top
PostPosted: Fri Aug 15, 2008 10:43 am    Post subject: Add User to Ignore List Reply with quote
absolury fine thank you very much much appreciated Thumbright
yes i have now and i echo benshaws comments
heeelllooo and welcome benshaw Thumbright Thumbright
the power is usefull more than the 40% from the extra capacity they have
its like you have an extra20% on top Thumbright
mind you its unnerving the battery stops dead like its broken on off just like that it will recover after a few seconds 2 or 3 times but no usefull power after it stops the first time
and another point i would rate 2 lion as equivilent to 4 normal as you can top up charge the night before and know you have fully charged batteries Thumbright
if you look on e bay theres a person selling 1 battery and charger for around £75 reapearing time after time
and sorry for the late replyes scratch
Back to top
chippymike
PostPosted: Fri Aug 15, 2008 4:43 pm    Post subject: Add User to Ignore List Reply with quote
thanks big all sounds like i need some for my impact driver then
Back to top
PostPosted: Fri Aug 15, 2008 7:19 pm    Post subject: Add User to Ignore List Reply with quote
funny enough the longest test for the batteries was with the impact driver 3 and 4" screws and coach bolts a load off decking it went on all day no probs Thumbright
Back to top
chippymike
add to the wish list lol
Back to top
Hitch
PostPosted: Fri Aug 15, 2008 7:25 pm    Post subject: Add User to Ignore List Reply with quote
I think if you go cordless, you really have to splash out on top notch gear.
cables are a pain sometimes, but having full power constantly is worth putting up with the cables.
Back to top
Thefunkymonkey
Junior Member
PostPosted: Sun Aug 17, 2008 4:13 pm    Post subject: Add User to Ignore List Reply with quote
I use a DeWalt 390, it will cope with just about anything. I use it for hardwood doors and 40mm worktops all the time, doesn't complain a bit.
I have a couple of standard 2.2ah ni-cad batts which are ok and a 3ah ni-mh i got from ebay. The 3 is a generic type, about 30 quid, but is far more powerful than the DW ones.
I'd highly recommend it to anyone, yet to make it struggle.
Back to top
Display posts from previous:
Post new topic   Reply to topic    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Tool Talk All times are GMT
Page 1 of 1
