It is currently Tue May 22, 2012 9:10 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 2 posts ]
PostPosted: Wed Sep 28, 2011 10:38 am
Has thanked: 6 times
Been thanked: 14 times
Hi Guys, as requested a few pics of my bathroom i'm doing up.
1950's council Semi, pipework is all battern / surface mounted
Pictures of how we recived it (after a few touchup's to make it prettier)
File comment: Layout from doorway, toilet pan sizing up
File comment: Original Bath - Steel / cast, no overflow, fresh bead of sealant partially done.
File comment: Bathroom before, pic after we had the lino put down
PostPosted: Wed Sep 28, 2011 10:56 am
First port of call was to replace the soil stack,
the previous stack consisted of a cast vertical with a iron trough / bucket ontop, down into a clay trap under the concrete path.
we'd dug out and replaced the clay trap with a plastic bend, a plastic to clay connector and a vertical,
Pictures are of the stack completed, with a 104 degree elbow (92 would have meant 2 elbows and 112 would end up too high)
(yes i'm a messy worker!, sorry!)
File comment: soil stack vent from bathroom window
File comment: toilet soil elbow from bathroom window
File comment: new plastic soil stack from bathroom window, tempory sink and bath pipes - 1
File comment: after core drilling, soil pipe through the wall
File comment: after core drilling, tidied up
Because the toilet we bought was flush wall fitting,
and i didn't fancy the prospect of moving all the supply pipe work
(main cold runs under the sink then under the bath and the hot adjacent)
we studded the wall out about an inch and a half and covered with laminated board.
Elbow arrangement feeds the toilet.
File comment: isolator arrangement, goes into a 15mm bent pipe then onto a flexi.
File comment: toilet fitted
File comment: toilet in final position
