Fan and lights in bathroom fitted by sparkey - shared switch. Fan should have a delay of 5 minutes after switching it off... But it doesn't... sparkey just shrugged his shoulders..
posting.php?mode=post&f=3# (the fan was already in place, had the light fittings replaced and a new switch installed)
the one in my ensuite works just fine - same sparkey.....
But the wires he used were different ..
The one that has the problem -- the switch has only red and black wires!!! (ignoring the earths)
one red wire into the com connection two red wires into the L1 connections. All 3 black wires are connected together.
posting.php?mode=post&f=3#Help - what needs to be changed in order to get the delay working again??
(the one that works a four core cable was used)
