It is currently Tue May 22, 2012 8:53 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 2 posts ]
PostPosted: Sat Nov 05, 2011 4:49 pm
I'm replacing the extractor fan in my bathroom. The previous fan had it's own pull cord, the new fan is a timer model I want to run off the light.
The old fan was running from a spur off a power socket ring main via a FCU.
The bathroom light is running from a spur off the lighting ring.
The plan was to take the FCU off the ring main, and then connect the FCU via the light - and onto the fan.
I assume I have to take the FCU off the ring main, otherwise there will be 2 rings connected to the same FCU.
Can I run the light and fan off the same lighting spur?
PostPosted: Sat Nov 05, 2011 5:04 pm
Has thanked: 1 times
Been thanked: 5 times
The Electrical Work/ammendments you are describing is notifable under part P and therefore should be under taken by a registered electrician.
Bearing in mind, RCD protection, Requirement for 3 pole isolation switch etc...
Users browsing this forum: No registered users and 7 guests
