It is currently Tue May 22, 2012 8:47 am
 Post subject: bath tap / shower tap
PostPosted: Wed Sep 30, 2009 4:49 pm
hi i have a bath tap that is a shower as well
this one:
http://www.toolstation.com/shop/Taps+Sh ... 691/p31467
when i go to pull the slector up to use the shower part of the tap and when i have how water only it pops back to the tap setting (i think its cos theres not enough pressure on the hot water) if i remove this tap and fit a tap that has a slector bar like this one:
http://www.toolstation.com/shop/Taps+Sh ... 691/p17413
will that work better then my currant tap
thanks for teh advice
 Post subject:
PostPosted: Wed Sep 30, 2009 5:11 pm
Has thanked: 17 times
Been thanked: 263 times
Yes, those types of diverter are a pain. You can bodge it by making a blocker ring to stop it closing out of a bit of plastic to slip under the spindle to hold it up. I did that on a similar unit that worked for some months until I got around to swapping the taps. The new unit has a diverter tap which will be far better.
 Post subject:
PostPosted: Wed Sep 30, 2009 5:30 pm
Been thanked: 5 times
some of those divertors you have to pull up and then twist.
have you tried?
 Post subject:
PostPosted: Wed Sep 30, 2009 8:43 pm
have you tried?
tryed that dident work
 Post subject:
PostPosted: Wed Sep 30, 2009 8:44 pm
so if i fit the one with a laver it will work fine then?
thx for the advice
Users browsing this forum: No registered users and 9 guests
