It is currently Mon May 21, 2012 1:19 pm
PostPosted: Sat Oct 30, 2010 8:19 pm
:help:
Hi all,
I'm converting a barn (into holiday lets) - it was built in 1888, Ruabon red brick 9 inch walls, so no cavity - and the BCO has recommended a bitumen type covering to be applied to the interior walls - 3 coats - which will be a hell of a job to apply by hand even if I use a roller or a yard brush.
The next steps will be to lap the DPC over this to a height well above ground level outside (the barn is on a hill) then tape it to the bitumen. Then studwork etc as normal.
I'm after some advice please - can bitumen type coatings be sprayed, or are there any other alternatives on the market, obviously I've looked on the net & asked around - I've got a guy from Sempatap coming around to quote but I doubt if I'll be able to afford it frankly.
Am I missing something? Wouldn't be the 1st time....
Incidentally - I am doing this on a Building Notice - hence no full spec plans.
Martin.
PostPosted: Sun Oct 31, 2010 9:26 am
Has thanked: 45 times
Been thanked: 124 times
I have found a mop to be an effective way to apply it. From the looks of it your just over the hill and a bit from me.
:welcomeuhm:
Mike
http://rebuildingatimberbungalow.blogspot.com/
any advice welcome
PostPosted: Sun Oct 31, 2010 6:05 pm
Thanks - that's not a bad idea at all.
Just come back in from a day cutting slots in walls.....knackered!
I've had a look at your blog, looks interesting - so where are you then?
PostPosted: Mon Nov 01, 2010 6:35 am
I havent really updated it for a long time - but I should be updating it at the end of the week.
Mike
any advice welcome
