Ultimate Handyman Home
Back half of double panel rad cold
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plumbing Forum -> Central Heating & Boilers
Hoovie
Devon DIYer
PostPosted: Sun Oct 07, 2007 4:19 pm    Post subject: Back half of double panel rad cold Add User to Ignore List Reply with quote
Drained down my system to fit Magnaclean, filled up again and went around bleeding the radiators...
Nearlty all my rads are double panel and I vented the air out ok on them, but one rad in particular seems to have a problem - the back of the rad seems a lot cooler then front and when I open the air bleed for the back half, nothing comes out - no air and no water.
Is there a simple fix for this?
Back to top
jason123
PostPosted: Sun Oct 07, 2007 7:23 pm    Post subject: Add User to Ignore List Reply with quote
Remove rad and wash through, it must be blocked.
Stella Stella Stella oy oy oy
Back to top
tim'll fix it
PostPosted: Sun Oct 07, 2007 9:45 pm    Post subject: Add User to Ignore List Reply with quote
yes there is a bit of muck in the bleed nipple
turn the valves on both side to off
then remove the nipple and poke a pin down the hole it will dislodge the blockage and then air will rush out and the water too. so have the nipple ready to put back in
jasons suggestion of washing it out is not a bad one either
Decking
Back to top
Hinton Heating
Gas/Heating Expert
PostPosted: Mon Oct 08, 2007 7:25 am    Post subject: Add User to Ignore List Reply with quote
think jim is right.
www.hintonheating.com
Back to top
Hoovie
Devon DIYer
PostPosted: Mon Oct 08, 2007 7:54 am    Post subject: Add User to Ignore List Reply with quote
I'll try Jims (?) idea Thumbright
Back to top
Jaeger_S2k
PostPosted: Fri Oct 12, 2007 11:41 am    Post subject: Add User to Ignore List Reply with quote
Jim?
Jim who?
HH is at the sauce again! Sad
Jaeger.
FSBF
Back to top
Hinton Heating
Gas/Heating Expert
PostPosted: Fri Oct 12, 2007 5:21 pm    Post subject: Add User to Ignore List Reply with quote
did it work????
Theres clingons on the starward bow, captain!
Back to top
Hoovie
Devon DIYer
PostPosted: Fri Oct 12, 2007 5:26 pm    Post subject: Add User to Ignore List Reply with quote
Hinton Heating wrote:
did it work????
Not tried yet, Trooper Laughing Weekend Job Crying
The Magnaclean is going nicely black though Thumbright
Back to top
Hinton Heating
Gas/Heating Expert
PostPosted: Fri Oct 12, 2007 5:33 pm    Post subject: Add User to Ignore List Reply with quote
i bet you cant resist the tempation to keep checking it! :)
so was the new boiler powerflushed then? Smile
this is my powerflush magnaclean, is about 400mm long!
Back to top
Hoovie
Devon DIYer
PostPosted: Fri Oct 12, 2007 5:46 pm    Post subject: Add User to Ignore List Reply with quote
Ohh, What a big one you have !! Laughing
I will admit (here only, not to boiler makers) that I never ended up having the powerflush Embarassed
How long did the system go before that Powerflush?? looks like a load of sludge got collected there!!
Only checked the magnaclean once so far - Thursday, so about 4 days after install, and the white plastic part had a film of black sludge on it. I actually emptied the the container and used it to fill with some inhibitor as still not installed the towel rad - which I wanted to use to fill the inhibitor through. Got 300ml in that way, and will top up again this weekend same way (if I got a 100L system, that should only lose me about 10ml of inhibitor if it mixed up nicely by then)
Back to top
Hoovie
Devon DIYer
PostPosted: Mon Oct 15, 2007 9:35 am    Post subject: Add User to Ignore List Reply with quote
Exactly as you said, Tim Thumbright
Back to top
Hinton Heating
Gas/Heating Expert
PostPosted: Wed Oct 17, 2007 4:35 pm    Post subject: Add User to Ignore List Reply with quote
That picture was taken on a boiler change, the system was about 25yrs old, and reported as working fine.
I did one last week, with only 6 rads, a primatic cylinder... The system was creating gas in the rads, and the downstairs rads never got hot along the bottoms.
I got out one small magnaclean, and 2 large magnacleans of sludge from the system!
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plumbing Forum -> Central Heating & Boilers All times are GMT
Page 1 of 1
