It is currently Mon Jul 23, 2018 2:45 pm
PostPosted: Thu Sep 07, 2017 11:27 am
I really could use some advice/confirmation of how to wire this rotary switch, this is off a bench drill (Fobco Star) and was three phase, however, I have changed the motor to single phase 240v. The switch operates the three phase motor but it can be used as 240V if reconfigured...now this is where my head hurts!
I have enclosed two photos of the switch which have been previously marked 123 and ABC.. All help sincerely appreciated :)
PostPosted: Thu Sep 07, 2017 12:20 pm
Has thanked: 44 times
Been thanked: 1297 times
Since it is up to the makers of the switch which terminals do what, all anyone can do is guess.
My guess is A - 1, B - 2, C -3
But as its "electrical work" you should have a multi meter. (Cost considerably less than £20) That way you can take out the guess work.
Expecting to be able to do "electrical work" with no multi meter is like hitting a screw in with a hammer, because you have no screwdriver. it will work, but its ridiculous.
PostPosted: Thu Sep 07, 2017 12:31 pm
Has thanked: 1076 times
Been thanked: 1008 times
It's a rotary switch. Common in industry.
The individual switches will probably be one on each "layer".
As someone-else says above A - 1 B - 2 C - 3
Also as he says check with a multimeter to make sure.
For this message the author Dave54 has received gratitude : james232
PostPosted: Thu Sep 07, 2017 12:38 pm
It has also been suggested : Mains Live 1 + A to motor, Mains neutral to 2 + B and to a link wire which is then coupled to 3 and then take C to the motor. I do have a meter but am uncertain how to actually test it on the switch., was this along your lines Dave?
PostPosted: Thu Sep 07, 2017 12:47 pm
What's the point of the link wire?
PostPosted: Thu Sep 07, 2017 12:54 pm
I have no idea, it was working on the three phase set up, maybe it needs to be changed somehow ??
PostPosted: Thu Sep 07, 2017 1:00 pm
You do that with starters with overloads. The overloads are three phase, and will trip the starter if any phase is "down", so if you're using the starter on single phase, you have to run one "leg" through two overload elements, and the other leg through the remaining one to balance things up.
Your's is "just" a switch AFAIK. So just use two of the "pairs"
You check it by using the meter on the resistance or "continuity" range ("Ohms" or a sort of inverted horseshoe symbol). The connections to each individual switch will show either open circuit or closed circuit (touch the leads together to see the difference) as you rotate the switch.
Motors should have "no volt" protection though, so you should have a "starter" rather than just a switch.
PostPosted: Thu Sep 07, 2017 1:06 pm
The new motor is a Crompton Greaves B56 0.25kw 4pole 1 Phase.
Ok, so to use two pairs, like A+1 2+B, where do the rest go? Apologies but am somewhat clueless to this.
PostPosted: Thu Sep 07, 2017 1:15 pm
Reading your last post. That's even weirder.
Are you sure it was set up like that with the three phase?
Are you sure it actually was three phase?
Problem is that there are all sorts of weird setups for all sorts of reasons. Without knowing what was exactly there and why, it's anyone's guess what was done and for why.
Normal setup would be switch - starter - motor.
So incoming live neutral, through the switch, then through the starter, and into the motor terminals.
Don't switch the earth!
PostPosted: Thu Sep 07, 2017 1:25 pm
Of course, see images enclosed, I did not wish to use an inverter hence buying a replacement single phase
PostPosted: Thu Sep 07, 2017 1:28 pm
And new motor is http://www.motors-direct.co.uk/index.php?_a=product&product_id=1552
PostPosted: Thu Sep 07, 2017 1:39 pm
Just to add that the original info I was given is pasted below, I just like to thoroughly check these things before I start connecting things up!
"I suggest you try the old trick used on 3 phase contactors which uses all the ways.
Couple mains Live to 1 and A to motor. Couple mains Neutral to 2 and B to a link wire which is then coupled to 3 and take C to the motor.
If you have a test meter then check that through first, if not a batten lamp holder and wire to that as a load before transferring it all to the motor.
(The latter part-Batten..I have no idea what it means)
PostPosted: Thu Sep 07, 2017 3:08 pm
As a motor can be dangerous, and you are not 100% sure what you are doing (This is nothing personal) I suggest you get an electrician in to do the job for you, as an electrician will have all the correct test gear to make sure everything is correct.
Any trades person who is good at their job will make said job look easy, that is because they know what to do, they don't guess.
Its all very well saying put this bit here and that bit over there, and it may well "work" but the important thing is, is it safe?
PostPosted: Thu Sep 07, 2017 3:19 pm
http://www.screwfix.com/p/loop-in-batte ... lder/8215d
I don't advise making test circuits using mains voltages.
That you have there is really the same as I said about the three phase starter. A "starter" is just a contactor, overload and usually push buttons, put in one convenient box. The (usually thermal but some old kit might have oil damped magnetic "dash-pots") overloads have to have the same current running through them or they'll trip. Hence wiring it up that way for single phase operation.
I can't see any reason for wiring a switch like that (But I'm prepared to be told there is one.) All you are doing is putting two switches in series. It can't hurt anything if you do wire it that way.
Finally someone else has posted while I was typing this.
He's right, if you're not 100% sure of what you're doing, get an electrician to do it.
PostPosted: Fri Sep 08, 2017 2:31 am
Has thanked: 682 times
Been thanked: 771 times
The question is for Retired Col if he is listening.
