It is currently Fri Jul 20, 2018 1:56 am
Post new topic Reply to topic  [ 51 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Sun Oct 15, 2017 9:32 am
Has thanked: 696 times
Been thanked: 28 times
Whatever
PostPosted: Sun Oct 15, 2017 4:58 pm
Approved Electrician
Has thanked: 163 times
Been thanked: 565 times
multiman wrote:
That will give you an estimate of load used by w/v=amps. Of course me new items can added to circuits.
Rcd works by earth leakage, rcbo are more intense and have live and neutral connected to them working similar to an individual rcd, allowing circuits to be used without tripping out an rcd.
It will not give you an estimate of the load. If I decided to power everything up at once in my house then I would blow the main incoming fuse. You have to allow for diversity.
BTW an RCD does not operate by earth leakage but by detecting an imbalance in the live and neutral conductors. Of course earth leakage will trip one but that is not how they work.
And of course an RCBO operates in a similar way to an RCD. That's because a RCBO is a RCD (with overload protection on it).
PostPosted: Sun Oct 15, 2017 5:46 pm
Maybe you underestimate my knowledge of electronics and electrical stop trying to insult me I am aware of imbalance across neutral and live across coil which activates trip. If I was to ask to you how a transistor works you would have to search the Internet for an answer, I don't need to have knowledge of components inside of the mcb and rcds and their functional purpose.
PostPosted: Sun Oct 15, 2017 5:47 pm
As for diversity am aware a diversity factor is allowed that why I said I will calculate load for you
PostPosted: Sun Oct 15, 2017 6:54 pm
UHM Super Moderator
Has thanked: 176 times
Been thanked: 599 times
He's not trying to insult you.
I'm no Electrician however OnlyMe is.
as for you multiman I reserve judgement.
Please play nicely both of you. :thumbleft:
PostPosted: Sun Oct 15, 2017 8:26 pm
PostPosted: Sun Oct 15, 2017 8:27 pm
Yes I am qualified electrician as well been doing for many years im educated to engineer status not that it matters.
PostPosted: Mon Oct 16, 2017 8:09 pm
I would not have to look up transistors on the internet. I spent nearly a year at University studying electronic engineering before I was was asked to leave for engaging in illegal activities.
I don't need to have a knowledge of components inside an internal combustion engine to know how to drive a car. But at least I would know if it was a petrol or diesel car and therefore I know what fuel to put into it to make it work.
PostPosted: Sun Oct 22, 2017 7:20 pm
Has thanked: 1 times
Been thanked: 1 times
hello Onlyme
all done i`m connection to the house consumer unit tomorrow
one more question i have the light switch and double sockets i have bought are all metal
and the back plate has a small earth screw
i have run earth tail cable from the earth on the socket to the back plate of the back box
as there is a earth screw on the back box is this OK or no need ?
thanks again Paul
PostPosted: Mon Oct 23, 2017 6:38 pm
It is good practice to add the flylead/earth tail - and I am sure all the sparks here would agree with me.
Although the socket screws will provide the required earth for the backbox, for the few minutes it takes to do the job properly then it's a no brainer.
PostPosted: Mon Oct 23, 2017 7:11 pm
Hello onlyme can you take a look at this please
I did the job today all working great thank you
the right the red cable which is now going into the new 32 amp running the shed
this cable was in the 5amp mcb but i ve put it in the the new 32mcb which is running the shed
Was there any point in moving it I just thought I would move it to the end where the new 32mcb is
if not ill move it back tomorrow
Thanks again for your kind help in this matter
Paul
PostPosted: Mon Oct 23, 2017 7:12 pm
hope i make sense the lower red cable
PostPosted: Mon Oct 23, 2017 7:18 pm
hello job done i hope !
PostPosted: Tue Oct 24, 2017 5:56 pm
You need to earth the armoured bit of the SWA
PostPosted: Tue Oct 24, 2017 7:17 pm
onlyme thanks for the info
i had the glands but no instructions came with them ?
at both ends shed and house consumer units
thank you again paul
