Page 1 of 1
[ 4 posts ] |
| Author |
Message |
wouldliketoknow
Posted: Thu Nov 24, 2011 7:00 pm |
| Newly registered Member |
Joined: Thu Nov 24, 2011 6:51 pm Posts: 2 Has thanked: 1 times Been thanked: 0 times
Hi folks,
Had a quick search around but can't find anything that specifically answers the question.
I am looking to put electric in the shed which is over a tarred drive/road from the house.
I believe easiest option is to cut the road and lay armoured cable but what depth should I be looking at? I would be proposing to sand/concrete it and the road is obviously not going to be cut up anytime soon. So it is not exactly going to be disturbed. There will be daily movement over the road/cable however.
There is a duct under the road but currently has kerosene supply going through it so I have ruled that out.
Thanks.
| Top |
register or
log in
Posted: Thu Nov 24, 2011 11:37 pm |
| Pro Carpenter |
Joined: Sat Dec 16, 2006 10:11 pm Posts: 10485 Location: redhill surrey an auld reekie laddie Has thanked: 133 times Been thanked: 468 times
as bruno says you must own the area concerned you cannot use any land you do not have full ownership off without permission
_________________ we are all ------------------still learning
| Top |
register or
log in
wouldliketoknow
Posted: Fri Nov 25, 2011 12:03 pm |
Hi folks, yes it is private.
| Top |
register or
log in
Page 1 of 1
[ 4 posts ] |
