-> The Lounge |
| Author |
Message |
Hitch Senior Member
Posted: Sun Sep 23, 2007 12:53 pm Post subject: Aquarium pump |
Going to set up the daughters birthday present tonight, a small 45litre aquarium. No instructions for setup
Id like to confirm something-
The filter pump has one large inlet, with a foot valve, and one large outlet that pumps the water down through a trickle system above the water level...
The pickup pipe, has a small inlet/outlet with a flexible hose with a small valve on the end, just below the impellor. Where does this pipe go? and what is its purpose?
At first, i though it was to prime the pump, but the impellor would be underwater, so theres no need to have that.... Or is it like a safety thing, that should be set just below the water level, so the pump sucks in air instead of pumping most of the water out if theres a problem
Will do a pic in a min if it helps  _________________ Why isn't the number 11 pronounced onety one? |
| Back to top |
Hinton Heating Gas/Heating Expert
Joined: 16 Jan 2006 Posts: 4296 Location: Bournemouth
Posted: Sun Sep 23, 2007 1:13 pm Post subject: |
pic & model may help _________________ www.hintonheating.com
| Back to top |
| Back to top |
Hitch Senior Member
Posted: Sun Sep 23, 2007 1:38 pm Post subject: |
Its a HaiYang Powerhead HY204
Cant upload a pic, having trouble with that...
Sorry, you have reached your maximum Upload Quota Limit of 1 MB  _________________ Why isn't the number 11 pronounced onety one? |
| Back to top |
Hitch Senior Member
Posted: Sun Sep 23, 2007 1:45 pm Post subject: |
Try that _________________ Why isn't the number 11 pronounced onety one? |
| Back to top |
Only-Me Senior Member
Posted: Sun Sep 23, 2007 6:27 pm Post subject: |
Looks like an air pump thingy.....................some filters as well as filtering,have an extra pipe to tuck behind a rock to give a constant jet of bubbles?
Maybe talking b*llox mind long time since I had a tank set up  |
| Back to top |
Hitch Senior Member
Posted: Sun Sep 23, 2007 6:31 pm Post subject: |
I thought that, but theres no exterior 'inlet' for the air, and the shop blokey said we'd need an airpump aswell.
Perhaps its air just to help keep the water moving  _________________ Why isn't the number 11 pronounced onety one? |
| Back to top |
Posted: Sun Sep 23, 2007 6:40 pm Post subject: |
i think its the air outlet _________________ www.hintonheating.com
| Back to top |
Hoovie Devon DIYer
Posted: Sun Sep 23, 2007 6:45 pm Post subject: |
Info that accompanied the video link hinton heating posted. Watching the video now - looks pretty informative
How To Set Up A Tropical Fish Tank
This film will show you how to set up an aquarium for tropical fish. It will show you how to add gravel, water, plants and equipment to the aquarium.
Step 1: You will need
fish tank with a cover and a light
heater
thermometer
filtration system
air pump
gravel
decorations
some aquatic plants
your fish
Step 2: The tank
There are many different types and sizes of tank available, and these days they are often sold as complete all-in-one packages that include all the accessories you will need. Seek advice from your fish retailer about which tank to buy, as this will determine the type and number of fish you can keep. Start by washing out your tank with clean, warm water, without detergent. Position it on a surface that will not buckle, and that is sturdy enough to take the tank's weight when full. It is usually best to use a stand or cabinet which is purpose-built for fish tanks, especially if you have a large tank.
Step 3: Adding Gravel
Always use aquarium gravel from a pet shop, as this will be safe for your fish. Wash the gravel until the water runs clear. Then spread it evenly in the tank.
Step 4: Decorations
There are a variety of decorations available for aquariums. Rocks, driftwood and novelty decorations can all add to the visual appeal of a fish tank. Rinse the decorations in tap water, and then place them into the tank. You can also attach a plain or printed backdrop to the back of your tank.
Step 5: Install equipment
Install a filtering system into your tank. Fish produce a large amount of waste, which needs to be filtered out of the water otherwise it will become toxic. There are several different types of filtration system available. They can be located inside the tank, outside the tank, or under the gravel. It's also important that the surface of the water is agitated so that oxygen can enter the tank water. In most cases the filtration system will be able to do this, but sometimes it's necessary to install a separate air pump which will produce air bubbles in the water. Your retailer will be able to advise you which equipment is the most appropriate.
Step 6: Heating
The crucial difference between a tropical and a coldwater tank is that the tropical tank needs to be heated. As a general rule, your heater will need to have one Watt of power for every litre of water in your tank. Set it to the appropriate temperature for the fish you want to keep. When choosing different species of tropical fish to keep together, choose species that thrive in the same temperature of water. Also put a thermometer in the tank and check regularly that the temperature is correct.
Step 7: Add water
Fill your tank up with cold tap water. TOP TIP Place a bowl onto the gravel and pour the water into the bowl. This will stop the gravel displacing from the force of the water. Most tanks will have a water line indicating where you should fill it to. Add some dechlorinator to the water, as per the instructions on the bottle. This will make the water safe for your fish.
Step 8: Wait
Switch on the filter and heater, and then wait for about 2 days before adding plants or fish. This will give the tank time to settle and warm up to the correct temperature.
Step 9: Plants
After a couple of days your tank is ready to be planted. There is a wide variety of aquatic plants available and your retailer will advise you which are appropriate for your aquarium. Rinse new plants under tap water, and then plant them into the gravel in your tank. It's a good idea to remove some tank water before planting the plants, to prevent spillage, and then return the water to the tank afterwards. If the water is murky after planting, allow some time for the filter to clear it before adding fish.
Step 10: Adding fish
You are now ready to go out and buy your fish. For detailed instructions on how to add the fish to your aquarium, watch VideoJug's film 'How to introduce new fish into a fish tank.' _________________ I went to a bookstore and asked the saleswoman, "Where's the self-help section?"
She said if she told me, it would defeat the purpose. |
| Back to top |
Posted: Sun Sep 23, 2007 7:05 pm Post subject: |
Is it an internal or external pump/filter  |
| Back to top |
Hitch Senior Member
Posted: Sun Sep 23, 2007 8:22 pm Post subject: |
Internal.....
None of the ones in the web info things seem to be like this one.
It just bobs about in the water, pump is much quieter with it in water than out. Its in for now, will check at the shop tommorw when i pick the fishys up  _________________ Why isn't the number 11 pronounced onety one? |
| Back to top |
Hoovie Devon DIYer
Posted: Sun Sep 23, 2007 8:25 pm Post subject: |
hope your daughter likes it
I'm well over 40 and I'm jealous  _________________ I went to a bookstore and asked the saleswoman, "Where's the self-help section?"
| Back to top |
yourweb Senior Member
Posted: Mon Sep 24, 2007 5:15 am Post subject: |
I tried a search for that model but g o o gle did not come up with anthing. Is there any more info on the pump? _________________ YourWeb.Info Online Shopping Mall |
| Back to top |
Jaeger_S2k Senior Member
Joined: 19 Nov 2006 Posts: 2786 Location: North West, England, United Kingdom
| Back to top |
Hitch Senior Member
Posted: Mon Sep 24, 2007 10:41 pm Post subject: |
Got the fish tonight.... looked and asked in the shop. It doesnt really do anything. Just pull the pipe off and leave it open.
Hope she likes it  _________________ Why isn't the number 11 pronounced onety one? |
| Back to top |
