-> Electric Forum UK |
| Author |
Message |
ricm Junior Member
Posted: Sun Nov 09, 2008 10:53 am Post subject: Appropriate sizes for Capping and Back Boxes |
Short & sweet question for a change... Need to order some parts.
Best size (depth) galvanised back boxes for power sockets, fused connection unit, data grids, light switches?
Best size (width) galvanised capping for two x 2.5mmsq T&E for power, one x 2.5mmsq for spurs, two x 1.0mmsq for 2-gang lighting?
Should back boxes now be fitted with grommets after punch-out?
Thanks,
Ric
| Back to top |
IDontBelieveIt Approved Electrician
Joined: 29 Jul 2008 Posts: 1192 Location: North Hampshire
Posted: Sun Nov 09, 2008 1:30 pm Post subject: |
Nothing less than 25 mm for backboxes.
50 mm for capping over 2 x 2.5 t/e
Grommets are not a requirement to BS7671 but are good practice, all decent sparkys fit them.
_________________ Never lie - that way you don't have to remember what you said. |
| Back to top |
Rich-Ando Approved Electrician
Joined: 24 Mar 2007 Posts: 2617 Location: Derby, Derbyshire
Posted: Sun Nov 09, 2008 1:43 pm Post subject: |
be careful when deciding which boxes to use though, if you use the deep ones there is a chance you will knock the bricks right through if you are not used to chopping them out.
fully agree with IDBI on the grommets, use them cos you would be surprised how many people cut through the insulation when they cram the socket fronts back on
capping, i never use the stuff myself, i find it dam annoying. it gives a week spot for plaster, it doesn't protect the cables from anything other than a plasterer hitting the cables with a trowel. that is the only reason it was used on building sites.
| Back to top |
Posted: Sun Nov 09, 2008 2:06 pm Post subject: |
lol Rich - know what you mean about capping or is the blooming capping nails that are the problem? I HATE capping nails and don't use them I prefer to use galv clout nails. Actually I prefer not to use capping at all and hardly do these days spreads are OK at doing their job generally speaking.
| Back to top |
Posted: Sun Nov 09, 2008 4:06 pm Post subject: |
i do all my own plastering so i know i don't have to use it
| Back to top |
ricm Junior Member
Posted: Sun Nov 09, 2008 7:26 pm Post subject: |
So if you don't use cappings how do you fix cables into the channel?
Ric
| Back to top |
ultimatehandyman Site Admin
| Back to top |
Stoday Electricity economics consultant
Joined: 20 Jan 2006 Posts: 3227 Location: Sitting on the Bog
Posted: Mon Nov 10, 2008 3:33 am Post subject: |
What a good idea UHM. And all these years I've been trapping cables under the heads of clout nails...
_________________ УГМ МОД — Пошёл на хуй |
| Back to top |
Steve the Gas Senior Member
Joined: 30 May 2008 Posts: 794 Location: Notts/Derbys
Posted: Mon Nov 10, 2008 6:04 am Post subject: |
| Back to top |
ricm Junior Member
Posted: Mon Nov 10, 2008 7:51 am Post subject: |
OK,
I only ever used clips before for surface mounting along joists and blockwork.
Thanks guys.
Ric
| Back to top |
Posted: Mon Nov 10, 2008 8:00 am Post subject: |
| Stoday wrote: |
Twit - I was referring to the fixing of capping.
Do you ever offer any serious and correct answers Stoday or is it permanent one-upmanship with you at all times?
| Back to top |
