Ultimate Handyman Home
Angle Bead
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plastering Forum
skiking
PostPosted: Fri May 18, 2007 2:46 pm    Post subject: Angle Bead Add User to Ignore List Reply with quote
I've Dot'n'dab'd some walls and now I need to stick some angle bead's on the external corners and around the window recess prior to plastering. What is the norm to attach these beads to the plasterboard ? I was going to use the drywall screws I'd used on the partition wall but these are quite long and will eventually hit the brick work but I doubt they will penetrate it. I've used 12.5mm boards and the shortest screw I've seen is 25mm. Confused
Quick answer appreciated as I need to go to Sfx Shocked Laughing
Back to top
skiking
PostPosted: Fri May 18, 2007 3:01 pm    Post subject: Add User to Ignore List Reply with quote
Now I've written the problem down I think the answer is obvious Shocked. Due to the size of the beading the screws will end up going in the gap behind the boad on the 90degree angle so the length of the screw doesn't matter - I think
Back to top
PostPosted: Fri May 18, 2007 3:25 pm    Post subject: Add User to Ignore List Reply with quote
You can screw the screw into the other piece of plasterboard, so that it misses the brick behind Wink
DIY | DIY Video
Back to top
PostPosted: Fri May 18, 2007 3:29 pm    Post subject: Add User to Ignore List Reply with quote
Like this-
 Description:
 Filesize:  5.88 KB
 Viewed:  881 Time(s)
DIY | DIY Video
Back to top
skiking
PostPosted: Fri May 18, 2007 3:35 pm    Post subject: Add User to Ignore List Reply with quote
Thanks for confirming for me. Thumbright
It was one of those things that as soon as I'd posted it I suddenly thought about the size of the bead and where it would screw into Embarassed Panick over
Back to top
andy-p-
pro plasterer
PostPosted: Fri May 18, 2007 4:18 pm    Post subject: Add User to Ignore List Reply with quote
I never screw them up, just butter them up with multi or staple them using a ...staple gun works a treat
Back to top
10yearsexp
Junior Member
PostPosted: Mon Jun 25, 2007 8:36 pm    Post subject: hold on wait a minute Add User to Ignore List Reply with quote
no screws
no staples
yes dry wall nails....... all pro plasterers use them..
when youve tried it and it doesnt work find me on forum and i will help.
dont use screws thats just mad
insane in the membrane
Back to top
andy-p-
pro plasterer
PostPosted: Tue Jun 26, 2007 6:09 am    Post subject: Add User to Ignore List Reply with quote
not all pros mate Wink
Back to top
10yearsexp
Junior Member
PostPosted: Tue Jun 26, 2007 8:13 am    Post subject: not all pros Add User to Ignore List Reply with quote
no your right i just gave the easy way
you like me prob stick up with set...
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plastering Forum All times are GMT
Page 1 of 1
